rtapi_print_msg
19 Apr 2024 09:18 #298610
by diammo
rtapi_print_msg was created by diammo
hello everyone, I wanna know where I can see the log printed from rtapi_print_msg.
20 Apr 2024 10:37 #298715
Replied by andypugh on topic rtapi_print_msg
It depends on the realtime version being used. If you are using RTAI then it goes into the kernel log. Otherwise it goes to stdio.
In the first case you can view it with the "dmesg" command, or by opeining a separate logging terminal and running "sudo tail -f /var/log/kernel.log"
In the latter case you can view it by starting LinuxCNC from the command line with the "linuxcnc" command.
20 Apr 2024 10:51 #298717
Also, if you want to increase the logging level you can do this either in the HAL file with the "debug" command or from the terminal (after startup of LinuxCNC) with "halcmd debug 5" (or some other level from the list RTAPI_MSG_NONE = 0, RTAPI_MSG_ERR = 1, RTAPI_MSG_WARN = 2, RTAPI_MSG_INFO = 3, RTAPI_MSG_DBG = 4 RTAPI_MSG_ALL = 5)
Time to create page: 0.073 seconds
