4rth axis to lift/lower mill head?
21 Apr 2024 23:25 #298804
by Rick4004
4rth axis to lift/lower mill head? was created by Rick4004
I have a "homebuilt"mill that has a z-axis travel of about 2.75" via the quill. The whole mill head is mounted on a set of linear guide rails that I can raise and lower with a gearmotor, but I never really know where the head is in relation to the table.
Would it be as simple as replacing the gear motor with a stepper, and setting up another axis "A?" in the software that would allow me to raise and lower the head and know were it is in relation to the table?
Seems too easy.
Seems too easy.
- Thank you received: 5945
22 Apr 2024 00:57 #298808
You can also add a home switch so it homes whenever you home the machine, that way you know exactly where the table is and can lower/raise from gcode.
Replied by tommylight on topic 4rth axis to lift/lower mill head?
Yes it is.Seems too easy.
