Mesa cards or parallel port? And where to learn about Mesa
- Thank you received: 5945
24 Apr 2024 21:13 #299026
Replied by tommylight on topic Mesa cards or parallel port? And where to learn about Mesa
In Portugal
eusurplus.com/index.php?route=product/product&product_id=159
In stock
In Germany
www.welectron.com/Mesa-Electronics-7i96S...thernet-Controller_1
Not in stock
In stock
In Germany
Not in stock
The following user(s) said Thank You: Alistair
26 Apr 2024 08:42 #299106
by Alistair
Replied by Alistair on topic Mesa cards or parallel port? And where to learn about Mesa
Thanks, I had looked at those dealers but with their mark up it's something like 20% more expensive after shipping.
I've ended up shipping from the US this seems to be the cheapest option.
Thanks again for the help, I'm sure you'll be hearing from me again.
26 Apr 2024 17:31 #299127
by zz912
Replied by zz912 on topic Mesa cards or parallel port? And where to learn about Mesa
You wrote that you were considering a tool changer. Calculate how many inputs and outputs you will need. If you miss them, consider a combination:
7i96s + 7i84
If you want to make a control panel with many buttons, I recommend a combination:
7i96s + cable DB25M-IDC26 + 7i74 + up to 9x 7i84
Of course, you can start only with the 7i96s itself and buy other cards afterwards.
There is also the question of whether the closed loop motors you are using have an encoder output and whether you want to introduce it into the LCNC.
7i96s + 7i84
26 Apr 2024 17:49 #299130
Of course, instead of 7i84, there are 7i70, 7i71, 7i72, 7i73 that can be used.
That or 7i96S + DB25-IDC26 + 7i85 + up to 5X 7i84 (4x on 7i85 and 1 on 7i96S)If you want to make a control panel with many buttons, I recommend a combination:
The following user(s) said Thank You: zz912
Time to create page: 1.421 seconds
