Failed to find entry point
25 Apr 2024 13:08 - 26 Apr 2024 04:00 #299065
by oushadz
Failed to find entry point was created by oushadz
Hello,
I installed qtpyvcp and linuxcnc but I get the error "Failed to find entry point: argecnc". I could not find the solution in the forum.
[qtpyvcp.app.launcher][ERROR] Failed to find entry point: argecnc (launcher.py:176)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 174, in _load_vcp_from_entry_point
vcp = entry_points[vcp_name.lower()].load()
KeyError: 'argecnc'
[qtpyvcp.app.launcher][ERROR] Could not load /home/mavijet/argecnc, make sure that the name or file path is correct. (launcher.py:134)
Running HAL shutdown script
task: 5 cycles, min=0.000008, max=0.010064, avg=0.003108, 0 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Note: Using POSIX realtime
Last edit: 26 Apr 2024 04:00 by oushadz.
26 Apr 2024 17:20 #299126
Replied by Aciera on topic Failed to find entry point
Seems that you are trying to load something that does not exist.
Time to create page: 0.201 seconds
