checkbox default setting
27 Apr 2024 18:34 #299202
by MaHa
checkbox default setting was created by MaHa
After I ported the pyvcp panel to glade, everything works, except the checkbox setting by default. At the moment the status is being restored via an ini file, but I would like the checkbox to be checked when starting. Is this possible?
04 May 2024 09:17 #299700
Replied by andypugh on topic checkbox default setting
Do you want to override the INI setting?
You may just need to remove the checkbox in question from the inivars string: linuxcnc.org/docs/2.6/html/gui/gladevcp....persistent_variables
08 May 2024 22:50 #300164
by MaHa
Replied by MaHa on topic checkbox default setting
It was about this checkboxes in the glade panel. Jog inhibit is essential for me, to prevent accidentally keyboard jog. Depending on clamping chuck or a-axis, i need to probe tool and z-offset at different positions.
The initial idea was, to have the boxes checked as default on start. I removed them from the inivars string, then they stayed unchecked. So i changed back to restore last state on start, and got used to it already, and i added leds to visualize more clearly.
Time to create page: 0.316 seconds
