LCNC2.9.2 Errors in log
- macsddau@linuxcnc
- Topic Author
- Thank you received: 28
28 Apr 2024 06:30 #299233
by macsddau@linuxcnc
LCNC2.9.2 Errors in log was created by macsddau@linuxcnc
Hello,
Using Terminal when staring linuxCNC I can read logs. I have solved some INI errors (missing parameters). LCNC works properly but I still have some errors that I don't know how to solve.
System info :
(gmoccapy:1852): Gtk-CRITICAL **: 08:18:37.526: gtk_entry_set_text: assertion 'text != NULL' failed
(onboard:1906): Gdk-CRITICAL **: 08:18:42.472: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
System info :
uname -a
Linux R883CNC 5.4.258-rtai-amd64 #2 SMP Thu Oct 19 11:54:56 BST 2023 x86_64 GNU/Linux
04 May 2024 09:34 #299703
Replied by andypugh on topic LCNC2.9.2 Errors in log
I think you can ignore these. (despite the "Critical")
The following user(s) said Thank You: macsddau@linuxcnc
Time to create page: 0.201 seconds
