Hal trigger when LINUXCNC launched but not else running
30 Apr 2024 20:33 #299418
by V34michel
Hal trigger when LINUXCNC launched but not else running was created by V34michel
Hi, I'm looking for a HAL signal to command a static relay to powered on all powers (ohmic, steppe drivers, thc..).
The purpose is to only powered on all the command system when LinuxCNC is launched and not only when the linux PC started.
I want to use a static relay linked to an output of my partport (ie P9). So i'm looking for a trigger event.
regards, Michel
regards, Michel
30 Apr 2024 21:37 - 30 Apr 2024 21:40 #299424
Replied by PCW on topic Hal trigger when LINUXCNC launched but not else running
Often a charge-pump is needed for parallel port setups
to come up in a defined state. The BIOs sometimes probes
the parallel port hardware and toggles output bits at startup.
That said, you could simply link motion.motion-enabled to parallel port
pin 9, something like this:
net linuxcnc-on motion.motion-enabled parport.0.pin-09-out
If the polarity is wrong you may need to add:
setp parport.0.pin-09-out-invert true
Last edit: 30 Apr 2024 21:40 by PCW. Reason: better motion pin
01 May 2024 06:31 #299441
by V34michel
Replied by V34michel on topic Hal trigger when LINUXCNC launched but not else running
"net linuxcnc-on motion.motion-enabled parport.0.pin-09-out."
it does not work. For additional information I use version 9.2.
I cannot find the linuxcnc-on motion.motion-enabled signal with the HAL viewer. On the other hand, using the :plasmac:torch-enable signal works, but that's not what I'm looking for. I would like a signal that would be active if LinuxCNC is properly launched.
Here is the line that I added in "custom_postgui.hal"
#POWER Relay
#net linuxcnc-on motion.motion-enabled => parport.0.pin-09-out
net plasmac:torch-enable => parport.0.pin-09-out
#POWER Relay
01 May 2024 06:37 #299442
by V34michel
"The BIOs sometimes probes the parallel port hardware and toggles output bits at startup"
I confirm, this is why I use 2 relays in series with the NO and NC contacts to activate the torch. The first is connected to the 'torch-enable' signal and the second to 'torch-on':
// custom_postgui.hal
#TORCH_ENABLE
net plasmac:torch-enable => parport.1.pin-03-out
setp parport.1.pin-03-out-invert 1
//"myproject".hal
net plasmac:torch-on => parport.1.pin-02-out
#TORCH_ENABLE
//"myproject".hal
- Thank you received: 5997
01 May 2024 12:49 #299454
Replied by tommylight on topic Hal trigger when LINUXCNC launched but not else running
e-stop-out
machine-is-enabled
amplifier-enable
x-enable
y-enable
there are many pins you can use, depending on what and under what circumstances it should go on.
Use a DVM to find an output pin that does not toggle during boot, usually there are 1 or more.
machine-is-enabled
amplifier-enable
x-enable
y-enable
01 May 2024 13:35 #299463
The hal net statement:
Does work, you may not find the signal linuxcnc-on because it is created by that
statement. As tommylight said, there are other pins you can use to drive your
parallel port pin but motion.motion-enabled should work.
01 May 2024 18:17 #299488
by V34michel
In fact it's half working : with this line
net linuxcnc motion.enable => parport.0.pin-09-out
when launch LinuxCNC, relay linked to pin-09 powered ON, but when I close LinuxCNC it doesn't stop. Have you an idea ?
regards, Michel
regards, Michel
01 May 2024 18:39 - 01 May 2024 18:41 #299497
Are you saying:
net linuxcnc motion.motion-enabled => parport.0.pin-09-out
does not work?
(it works for me but only goes on when the machine in the power-on state)
I chose motion.motion-enabled rather than motion.enable because it goes false
when you toggle LinuxCNC power (the power button on the screen) so a normal
shutdown turns it off
does not work?
Last edit: 01 May 2024 18:41 by PCW.
01 May 2024 19:30 #299503
There was another topic (or was it this one) to use the shutdown.hal to reset the port when LinuxCNC exits, but somehow it went quiet, or i was to busy.
That is normal for parallel port, it does not reset by itself, so if you are trying to do that, you will need a charge pump.when launch LinuxCNC, relay linked to pin-09 powered ON, but when I close LinuxCNC it doesn't stop.
02 May 2024 14:26 #299556
by V34michel
<<net linuxcnc motion.motion-enabled => parport.0.pin-09-out>>
yes, it's working but not my initial target.
Initialy I wanted to power on all powers (main and ohmic) at Linuxcnc start. It's working at start but when we quit LinuxCNC, it doesn't cut the power (I don't find a signal activated by quit-yes).
So I decided to only drive the ohmic power and with <<net linuxcnc motion.motion-enabled => parport.0.pin-09-out>> it"s fine. Thank you for help and patient.
Time to create page: 0.523 seconds
