Z Axis Homing and Movement Issue
- N3pu
- Thank you received: 3
01 May 2024 07:34 - 01 May 2024 07:44 #299445
by N3pu
Z Axis Homing and Movement Issue was created by N3pu
Hey Guys,
during the setup of the last axis (Z) I copied the section from X and Y Axis in the Ini file and adjusted the Limits of movement for Z and the changed the Sign for the Homing Search and Latch. Z will be homed in High Position (Z+).
Two Issues I can not resolve:
1) During Homing (Z Axis moving Up in direction Z+ to Ref-Sensor) the UnitCount in LinuxCNC is about 1000 mm (and then linux cnc Stops and prompt a message "J2 Bewegungsende im Referenzstatus 7"). If I press again Z-Ref the the Homing proceeds well until Z-Ref Sensor is reached.
So the travel of such long way (like the display) says is crazy. I just have a travel of about 500 mm on Z.
2) After Homing processed discribed in "1)" I can move the axis DOWN with the right measurement count.
BUT if I like to move the Axis UP again it didn´t works. Just a few µm and then linux CNC says "0.000" position of Z.
It seems like it rehomed during the DOWN move. Can´t understand.
I rechecked Positions with measurement tools and in the Servodrive. Everything is real, exept the value on LinuxCNC Z Position.
Last edit: 01 May 2024 07:44 by N3pu.
- N3pu
01 May 2024 13:20 #299460
by N3pu
Replied by N3pu on topic Z Axis Homing and Movement Issue
I created a video for issue 2)
- Thank you received: 7266
01 May 2024 19:00 #299499
Replied by tommylight on topic Z Axis Homing and Movement Issue
That helps in bringing up more questions, so
-what controller
-what drives
-what control type (step/dir, analog, PWM)
One thing is for sure, not a LinuxCNC issue with homing or whatever, the only thing i can think of in a hurry is too short step time or motor skipping.
-what controller
-what drives
- Thank you received: 5174
01 May 2024 19:38 #299505
Replied by PCW on topic Z Axis Homing and Movement Issue
As tommylight suggests I would try lengthening the step pulses
just to eliminate that as a possible issue (say to 1000 ns)
- N3pu
03 May 2024 18:21 #299651
by N3pu
Yeah, you could be right, that the problem is outside LinuxCNC.
My though was it´s linuxCNC (config) because of I copied the Z Axis by hand in the Ini-File (X and Y which are working are created in PNC-Conf) AND moving the Z Axis DOWN there seems to be no difference in way of moving.
I also have on X, Y and Z the same Servo Drive (Kollmorgen S346 with Firmware 3.89). Maybe the drives have different Hardware configuration - I will recheck. Motors are slightly different on X/Y and Z. Motors have Multiturn-Encoders connected to the Drive and they are in closed loop (drive and motor). So if something should be wrong it only can only be the step / dir signal between Mesa 7i76e and Servo Drive.
Servo Drive is rated at 1,5 MHz frequence for the step / dir interface. Cable is 30 cm.
I will recalc everything and give it a try on the weekend to change the timing for test, even if this timing is working fine on X and Y Axis...
I also noticed the resistor in the rs485 line - at the moment I havn´t insert this end-resistor. Could be an issue too.
- N3pu
04 May 2024 17:19 #299742
by N3pu
Today I increased the step timing from 0,5 µS to 1µs each (high and low) but there was no change.
Then I was thinking again about that down seems to work (maybe only better) and up is more crazy.... So I recheckt my cabeling from Mesa to Drive - specially the DIR signal.
Here there was a missing contakt on DIR - (I think I crimped without stripping or someting like this). So crimped again and everything seems to work fine! Because of the floating DIR- the step count was sometime Up and sometime Down...
Thank you guys!
Thank you guys!
Time to create page: 0.090 seconds
