Combine all Home and LImit switches
12 May 2011 11:22 #9740
by BigJohnT
Replied by BigJohnT on topic Re:Combine all Home and LImit switches
You will have to as part of your homing defining a home location that moves each axis off the switch before homing the next axis.
12 May 2011 12:13 #9744
by czerech
Replied by czerech on topic Re:Combine all Home and LImit switches
it it set like You said. After homing proces, switch is relased.
its look like this:
1. i only enable limit switches on one axis in HAL file (AXIS 0)
2. i got 4 switches connected together in row to one LPT pin
3. Axis 0 is homing perfect (here i have enabled limit switches)
4. When Axis 1 trigger limit switch program is stoped.
if I disable limit switch function in Axis 0, both Axis are homing good.
so i suspect i must include information in INI file, that i have all limit switches and homing switches of both axis connected in row to one LPT pin...
but i dont know how to do this ;/
i have: "HOME_IGNORE_LIMITS = YES" in both axis
regards,
Piotr
its look like this:
regards,
Piotr
12 May 2011 12:47 #9748
by BigJohnT
Monitor the input pin in Show Hal Configuration watch window while you home to see if it changes as you expect from on to off.
Also, HOME_IS_SHARED = 1 should be in each axis section.
www.linuxcnc.org/docview/html/config_ini_config.html#sub:[AXIS]-section
12 May 2011 12:55 #9749
by czerech
thanks John a lot for help
i got in both axis HOME_IS_SHARED = 1
i will check when i go home what signal i have i hal when limit shitch trips.
regards,
Piotr
regards,
Piotr
12 May 2011 17:51 #9765
by czerech
i checked Hal Configuration, everything is changing in the way i expect it.
when base proces is running, when the first limit switch trips, all 4 pins change status:
net all-home => axis.0.neg-lim-sw-in
net all-home => axis.0.pos-lim-sw-in
net all-home => axis.2.neg-lim-sw-in
net all-home => axis.2.pos-lim-sw-in
maybe i should use some other function to provide limit switch after homing?
12 May 2011 18:22 #9766
by BigJohnT
And I assume you also have in your ini
net all-home axis.0.home-sw-in
net all-home axis.2.home-sw-in
Which should work...
12 May 2011 18:27 #9767
by czerech
net all-home => axis.0.home-sw-in
net all-home => axis.2.home-sw-in
yes i have those 2 lines
12 May 2011 18:28 #9768
by BigJohnT
If you have a spare input try putting all the X axis on one pin and all the Z on the other... then you have something like:
net home-x <= paraport.0.pin-10-in
net home-x => axis.0.neg-lim-sw-in
net home-x => axis.0.pos-lim-sw-in
net home-x => axis.0.home-sw-in
12 May 2011 18:31 #9769
by czerech
i think i must do it that way...
i was just trying to use only one pin instead of two.
12 May 2011 19:15 #9770
by czerech
when i used 2 pin, everything works fine
thanks John for helping, but if You will figure how to use only one pin, plz give me a sign
regards,
Piotr
regards,
Piotr
Time to create page: 0.426 seconds
