Cannot set auxiliary digital output with cutter ..
- frankbatzen
14 May 2011 12:00 #9802
by frankbatzen
Cannot set auxiliary digital output with cutter .. was created by frankbatzen
somewhat connected to my question here:
www.linuxcnc.org/component/option,com_ku...0/lang,english/#9800
I have the following question: When I have G41/G42 on and try to switch on a digital output (M64 P01) I get the following error message:
"Cannot set auxiliary digital output with cutter radius compensation on". But I would like to
So, is there any way to configure EMC2 to allow this? And why is it impossible in the first place?
frankbatzen
frankbatzen
14 May 2011 12:47 - 14 May 2011 12:49 #9803
by BigJohnT
Replied by BigJohnT on topic Re:Cannot set auxiliary digital output with cutter ..
There is no configuration for allowing that. I don't know but ASSUME that is will break blending or something like that.
www.linuxcnc.org/docview/html/gcode_main.html#sec:M62-to-M65
Use M62/63 instead.
Use M62/63 instead.
Last edit: 14 May 2011 12:49 by BigJohnT.
- frankbatzen
14 May 2011 16:09 #9807
by frankbatzen
Replied by frankbatzen on topic Re:Cannot set auxiliary digital output with cutter ..
Thanks for your help, John.
However, with M62/M63 I'm just getting another error message: "Cannot set motion output with cutter radius compensation on"
It would seem strange to me if EMC2 really did not allow switching the digital output on with cutter radius compensation on. Don't people normally use the digital outputs while milling?
regards,
frankbatzen
regards,
frankbatzen
14 May 2011 16:22 #9809
by BigJohnT
I don't know of any reason to use a digital output when milling. Looks like cutter comp is picky for some reason or another. There are several things ( I forget what exactly ) that are not allowed with cutter comp...
Time to create page: 0.133 seconds
