SETUP OF MESA 5I20/7I29 FOR DC SERVO MOTORS
18 Sep 2011 20:51 #13272
Replied by cmorley on topic Re:Encoder scaling
PWM rate does not play into encoder scale.
PWM rate _MUST_ be properly set for the daughter card used.
encoder scale means encoder pules per unit of movement (say inches assuming imperial lathe) including gearing and lead screw lead.
If you know your gearing ,encoder counts and lead screw pitch you can calculate it.
or you can manually figure it out:
zero the scale and move the axis exactly 1 inch that is your scale ( though it may be off slightly it is hard to move exactly 1 inch but the number you get could help you figure out the real scale)
In the open loop test if you are just manually moving the encoders then only the encoders will show changes.
I f you enable the amps and press the plus or minus keys then the other boxes should show changes.
set the DAC number low to start with there is no ramping up or down in an open loop test.
- NICKKINSMAN
18 Sep 2011 22:30 #13273
by NICKKINSMAN
Replied by NICKKINSMAN on topic Re:Encoder scaling
Great, that is just what I was doing, think I have it pretty close.
19 Sep 2011 00:51 #13275
Replied by PCW on topic Re:Still no output from the 7i29!
Yes you need a large electrolytic capacitor on the output of the rectifier to absorb reverse energy from the motor inductance(s) Probably on the order of 10000 uF. Its not safe to run without this capacitor
- NICKKINSMAN
19 Sep 2011 11:52 - 19 Sep 2011 12:08 #13289
by NICKKINSMAN
Replied by NICKKINSMAN on topic Capacitance on DC drive
OK, I will get one ASAP!
Will adding this jump up the voltage at all?
I see one at Mouser, 100VDC, 10,000 uF, looks about right.
Reason I ask is I am at 90V currenty, don't want to add the capacitor and have it jump up over the capacitor's 100V rating.
Thanks!
Thanks!
Last edit: 19 Sep 2011 12:08 by NICKKINSMAN.
19 Sep 2011 14:33 #13296
Replied by PCW on topic Re:Capacitance on DC drive
What is the voltage rating of your transformer?
if its 90VAC then the DC bus will be around
127V So you would need at least a 150V capacitor
If you have a three phase transformer/bridge,
the measured DC voltage with no filter will
be close to your final DC filtered voltage (127 with 90VAC)
- NICKKINSMAN
19 Sep 2011 17:34 #13310
by NICKKINSMAN
Replied by NICKKINSMAN on topic Re:Capacitance on DC drive
Transformer is running at 60VAC 3PH output, then it goes to the rectifier bridge, (no capacitor) comes to 90VDC (so 30V jump).
So, looks like the 90VDC unfiltered should remain close, and if I get a 100VDC capacitor, I should be fine, or should I upsize a little?
I've never really dealt with DC capacitors, how does it get hooked in the line, accross +/- in parallel or series on the +?
Thanks!
Thanks!
19 Sep 2011 19:42 - 19 Sep 2011 19:44 #13315
So at 90VDC you have some more margin so 5000 uF is fine,
but I would use a higher voltage, so you have some margin for motor inductive energy dump
and deceleration probably at least a 150V capacitor
You may be better of with a couple of smaller capacitors instead of one big one
These connect across the DC output of your rectifier (parallel) and polarity is very important
Another issue is ripple current capability, this will probably force you to use a large capacitor
search.digikey.com/scripts/DkSearch/dksu...36D161HPN153MDA5M-ND
is a nice 15000 UF cap
Last edit: 19 Sep 2011 19:44 by PCW.
- NICKKINSMAN
19 Sep 2011 22:50 #13319
by NICKKINSMAN
Well, I suppose this conversation is going to go on forever!
I've got the capacitor coming, I ordered one with 100V, 10,000uF from Mouser before your final post, but I may go ahead and order another from digikey too, if recommended. The Mouser one said it takes high ripple current and can take 20% +/- on voltage, so I thought it would work.
How will I know it is working properly, put a tester on the leads and monitor voltage?
Time to create page: 0.359 seconds
