7i80DB
- gandalf
13 Feb 2013 04:02 #29977
by gandalf
7i80DB was created by gandalf
When will be supported the 7i80DB?
- micges
- Thank you received: 3
13 Feb 2013 05:18 #29984
by micges
Replied by micges on topic 7i80DB
hostmot2 driver for 7i80 is working but still needs few weeks for stabilisation. In few days I'll create wiki page how to install and test this driver and test it yourself.
- gandalf
15 Feb 2013 21:04 #30111
by gandalf
Replied by gandalf on topic 7i80DB
what differences does it make use a 7i80-25 or 7i80-16 ?
- Thank you received: 5095
15 Feb 2013 21:33 #30115
Replied by PCW on topic 7i80DB
The only difference is FPGA size.
(XC6SLX16 vs XC6SLX25 FPGA chip)
Unless you have a very complicated machine
the 7I80-25 is overkill for LinuxCNC applications
- micges
16 Feb 2013 01:46 #30133
by micges
- sneci
02 May 2013 14:14 #33512
by sneci
Replied by sneci on topic 7i80DB
How the projekt running? Can I try the 7i80hd card?
I'm excited about developments.
- bigalex
- Thank you received: 4
17 Jun 2013 21:42 #35741
by bigalex
Replied by bigalex on topic 7i80DB
Hi people.
What is the actual situation of the 7i80 card ?
Is it still in Beta ?
How long it takes to get 7i80 card driver stable ?
bigalex
bigalex
17 Jun 2013 23:18 #35744
We haven't pushed this too hard because we are waiting for the Xenomai version (well multi RT version really) of LinuxCNC to get stabilized. The 7I80HD,7I80DB, 7I76E and 7I77E will not be supported by the RTAI based kernels (It was decided early on that this was too much work)
- bigalex
17 Jun 2013 23:33 #35746
by bigalex
Hi PCW.
Ok ....
I hope this will be soon .
The market trend is to use ethernet for realtime connections with devices for I/O and motion applications .
I clearly understand that this is not a standardized "bus" frame as Profinet, EtherCAT, SercosIII, EthernetIP and so on .
But it can give flexibility to the hardware connection from PC to motion hardware modules (7I80 ... ).
Keep us updated please .
Regards
bigalex
Ok ....
Regards
bigalex
- hardware_crash
12 Aug 2013 17:42 #37585
by hardware_crash
Replied by hardware_crash on topic 7i80DB
Dear PCW
Any news about the compatibility of the 7i80DB and the 7i76E ?
Regards
Regards
Time to create page: 0.283 seconds
