Setting up 5i25+7i85+8i20
25 Mar 2018 19:45 #107838
Replied by PCW on topic Setting up 5i25+7i85+8i20
In any case you will need speed feedback, sure how that will work with just hall effect
sensors
sensors
25 Mar 2018 21:07 #107846
It would probably work quite well if the bldc component had a velocity output. But that is something I forgot to add.
A ddt on the angle data ought to work, except that it wraps every rev.
So probably a little hal component would be needed
Replied by andypugh on topic Setting up 5i25+7i85+8i20
sensors
25 Mar 2018 23:48 - 25 Mar 2018 23:49 #107861
by blazini36
May sound silly but can't the signal fromnone hall sensor pin be connected to the encoder component to provide a velocity? It's been a while since I messed with hal
Replied by blazini36 on topic Setting up 5i25+7i85+8i20
sensors
Last edit: 25 Mar 2018 23:49 by blazini36.
25 Mar 2018 23:56 #107866
Yes, you can use the output from 1 (counter mode) or 2 (quadrature mode) hall sensors into the encoder component, but the duty-cycle isn't quite right so some smoothing would be needed.
26 Mar 2018 00:31 #107868
by blazini36
I didn't think quadrature would work since the hall sensors are not at 90 degrees.
By smoothing, do you mean something like the lowpass filter?
I assume Ill want to dump this into the motion controller, " => motion.spindle−speed−in"?
26 Mar 2018 00:37 #107870
Yes, I meant lowpass. And each pair of halls does a sort-of quadrature, enough to determine direction. They just have uneven timing so a velocity based on them will be noisy.
You don't actually need to send the velocity to motion on a milling machine. The point of having it is to use it with a PID component to get closed-loop velocity control.
01 Apr 2018 15:15 #108213
by blazini36
Using the hall sensors with the encoder component for a velocity feedback seems to work well. I would expect to see 16 counts from the 2 hall sensors in x4 mode but I see 12 per revolution so I have the encoder scale at 12. Lowpass gain of .01 seems to give a smooth velocity.
I am having alot of trouble with the PID loop. I can get it decent when the max output is limited to 2(amps), when I raise it to 7 I can't get the speed to come down. One thing I read suggests when tuning the PID, you should set I and D to 0 and raise P until the output oscillates, then I until the oscillation stops. I assume by "oscillate" it means starts making minor corrections when it's at speed. and not swinging between positive and negative values.
I seen PCW mention in another post that I and D should be left at 0 until it's close and only use P and FF0 until then, I have not tried this yet. I'm pretty sure I had to backdown on P because the motor would bang back and forth between hall counts when stopped. Looking at the docs, it says " the deadband should be set slightly more than one-half count". Does this actually mean .5 which is 1/2 of 1 count, or 6 which is 1/2 of counts per rev?
01 Apr 2018 16:09 #108215
For a spindle where the PID command is velocity and the PID output is torque,
you mainly want P and I
FF0 makes sense if the PID input and output are velocity but that's not the case with a torque mode drive.
Tuning a velocity loop is going to be tough with such poor (hall effect only) feedback, unless the spindle inertia
is quite high relative to the torque
01 Apr 2018 17:27 #108220
And for a spindle I would expect to be using I more than P. (The output of the P-term is zero when at the setpoint, but clearly 0 Amps won't give you a steady speed. Whereas it does give you a fixed position in a position loop)
01 Apr 2018 17:55 #108221
by blazini36
Would it be better to use the spindles drilled disk for feedback than the hall sensors on the motor? It's a single photo interrupt sensor so no quadrature, and the disk only has 4 holes but theyre more consistently spaced than the 2/3 hall sensors. It'll be a bit before I get the parts to add the differential encoder to the motor so one of these will have to do for now.
Time to create page: 0.151 seconds
