Installing and checking firmware on mesa 5125
27 Feb 2016 18:15 #70714
by Ncmill.ts
Installing and checking firmware on mesa 5125 was created by Ncmill.ts
hi im trying to check firmware on my 5125card and7177dautherboard.im frustrated as hell sins i cant find any decent step by step instruktion on the matter other than one on www.wiki.eusurplus.com/index.php?title=Category:Mesa_Interface.
im very new to linux and im obviously doing someting wrong,can firmware be check and installed in any other way than with"terminal window commands??.
i have bougt a 5125 and 7177 card from eusurplus.com ,not a plug and go kit so i think a need to install new firmware.
i have put som additional 5125 folders under the hostmot2 folder that i downloaded from mesas homepage xlm files and .bit .pin etc.
i typed sudo nautilus in terminal window and used tts as password and i got into root.
i have not been able to verify or flash firmware to my 5125card .and i have change permissions under properties on all files and folder under/hostmot2 to "tts"
when atempting to flash firmware into 5125card thru terminal i get "unknown command"
a simple step by step instruction would be appreciated.
also "sudo" is that a run or execute command???.
27 Feb 2016 18:33 - 27 Feb 2016 18:34 #70715
Replied by PCW on topic Installing and checking firmware on mesa 5125
1. Download 5i25.zip from Mesa
freeby.mesanet.com/software/parallel/5i25.zip
2. Unzip the 5i25.zip file
3. in a terminal window cd to the newly created configs/hostmot2/ directory
4. in the same window typeand then
sudo mesaflash --device 5i25 --write 5i25_7i77x2.bit
sudo mesaflash --device 5i25 --reload
Last edit: 27 Feb 2016 18:34 by PCW. Reason: clarify
27 Feb 2016 19:06 #70717
by Ncmill.ts
Replied by Ncmill.ts on topic Installing and checking firmware on mesa 5125
this is what i get.
am i typing it wrong or what.
27 Feb 2016 19:14 #70718
You need to install mesaflash:
sudo apt-get install mesaflash
27 Feb 2016 19:35 #70721
by Ncmill.ts
then i get this
some text are in swedish but on line E: it says "E: unable to locate(or find) pakage mesaflash
27 Feb 2016 19:41 - 27 Feb 2016 19:43 #70722
What linuxcnc installation (OS+linuxcnc version) do you have?
the
should work on the stock linuxcnc package
the
Last edit: 27 Feb 2016 19:43 by PCW.
27 Feb 2016 19:46 #70723
by Ncmill.ts
ubuntu 10.04 lts lucid lynx
27 Feb 2016 19:50 #70724
what linuxcnc version?
27 Feb 2016 20:04 #70726
by Ncmill.ts
linuxcnc 2.50
27 Feb 2016 20:09 #70727
Ahh, that's probably too old to have the mesaflash package available
I would probably update linuxcnc to 2.7.4
you might try
sudo apt-get update
and then sudo apt-get install mesaflash
but I expect 2.5 is just too old
you might try
sudo apt-get update
Time to create page: 0.083 seconds
