pncconf bug
13 Jul 2016 03:06 - 13 Jul 2016 03:06 #77366
by vre
pncconf bug was created by vre
If make a sample lathe configuration with pncconf and select
step-dir & encoder for Z axis and for step-dir only for X axis i get
(2 step generators & 1 encoder)
there is some conflict in signals.
the auto generated hal file
Found file(REL): ./test1.hal
./test1.hal:129: Signal 'z-pos-fb' can not add OUT pin 'hm2_5i24.0.encoder.00.position', it already has OUT pin 'hm2_5i24.0.stepgen.00.position-fb'
Running HAL shutdown script
# Generated by PNCconf at Wed Jul 13 05:14:30 2016
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config="firmware=hm2/5i24/SVST4_8.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2"
setp hm2_5i24.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
addf hm2_5i24.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_5i24.0.write servo-thread
# external output signals
# external input signals
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# Step Gen signals/setup
setp hm2_5i24.0.stepgen.01.dirsetup [AXIS_0]DIRSETUP
setp hm2_5i24.0.stepgen.01.dirhold [AXIS_0]DIRHOLD
setp hm2_5i24.0.stepgen.01.steplen [AXIS_0]STEPLEN
setp hm2_5i24.0.stepgen.01.stepspace [AXIS_0]STEPSPACE
setp hm2_5i24.0.stepgen.01.position-scale [AXIS_0]STEP_SCALE
setp hm2_5i24.0.stepgen.01.step_type 0
setp hm2_5i24.0.stepgen.01.control-type 1
setp hm2_5i24.0.stepgen.01.maxaccel [AXIS_0]STEPGEN_MAXACCEL
setp hm2_5i24.0.stepgen.01.maxvel [AXIS_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= axis.0.motor-pos-cmd
net x-vel-cmd <= axis.0.joint-vel-cmd
net x-output <= hm2_5i24.0.stepgen.01.velocity-cmd
net x-pos-fb <= hm2_5i24.0.stepgen.01.position-fb
net x-pos-fb => axis.0.motor-pos-fb
net x-enable <= axis.0.amp-enable-out
net x-enable => hm2_5i24.0.stepgen.01.enable
# ---setup home / limit switch signals---
net x-home-sw => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_5i24.0.stepgen.00.dirsetup [AXIS_2]DIRSETUP
setp hm2_5i24.0.stepgen.00.dirhold [AXIS_2]DIRHOLD
setp hm2_5i24.0.stepgen.00.steplen [AXIS_2]STEPLEN
setp hm2_5i24.0.stepgen.00.stepspace [AXIS_2]STEPSPACE
setp hm2_5i24.0.stepgen.00.position-scale [AXIS_2]STEP_SCALE
setp hm2_5i24.0.stepgen.00.step_type 0
setp hm2_5i24.0.stepgen.00.control-type 1
setp hm2_5i24.0.stepgen.00.maxaccel [AXIS_2]STEPGEN_MAXACCEL
setp hm2_5i24.0.stepgen.00.maxvel [AXIS_2]STEPGEN_MAXVEL
net z-pos-cmd <= axis.2.motor-pos-cmd
net z-vel-cmd <= axis.2.joint-vel-cmd
net z-output <= hm2_5i24.0.stepgen.00.velocity-cmd
net z-pos-fb <= hm2_5i24.0.stepgen.00.position-fb
net z-pos-fb => axis.2.motor-pos-fb
net z-enable <= axis.2.amp-enable-out
net z-enable => hm2_5i24.0.stepgen.00.enable
setp hm2_5i24.0.encoder.00.counter-mode 0
setp hm2_5i24.0.encoder.00.filter 1
setp hm2_5i24.0.encoder.00.index-invert 0
setp hm2_5i24.0.encoder.00.index-mask 0
setp hm2_5i24.0.encoder.00.index-mask-invert 0
setp hm2_5i24.0.encoder.00.scale [AXIS_2]ENCODER_SCALE
net z-pos-fb <= hm2_5i24.0.encoder.00.position
net z-vel-fb <= hm2_5i24.0.encoder.00.velocity
net z-index-enable axis.2.index-enable <=> hm2_5i24.0.encoder.00.index-enable
net z-pos-rawcounts <= hm2_5i24.0.encoder.00.rawcounts
net z-home-sw => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
Last edit: 13 Jul 2016 03:06 by vre.
- Thank you received: 5925
28 Jul 2016 01:33 #78089
Replied by tommylight on topic pncconf bug
You have 2 duplicate entries in the hal file for Z axis, so you need to comment one pair of them, use the "closed loop stepper" signals and comment out or delete the "encoder" part, or use the "encoder" part ane delete or comment out the entries with z-pos-fb in the "closed loop stepper" part.
Regards,
Tom
Regards,
Tom
Time to create page: 0.065 seconds
