PncConf and backlash
- BruceSherry
25 Oct 2016 03:55 #82024
by BruceSherry
PncConf and backlash was created by BruceSherry
Maybe this isn't a great idea, but my machine has some backlash, and I am trying to compensate for it.
I have a 5i25 with an MX3660. My problem is that on each axis that I put backlash compensation on, the STEPGEN_MAXVEL and STEPGEN_MAXACCEL terms do not appear in the .ini file that pncconf creates. This causes linuxcnc to crash complaining about the missing values.
I would think turning on backlash compensation shouldn't cause linuxcnc to crash. I can manually put them in, but it seems like a bug in pncconf to me.
Bruce Sherry
Bruce Sherry
25 Oct 2016 10:40 #82033
Replied by andypugh on topic PncConf and backlash
Are you setting up backlash comp inside PnCConf, or separately? If PnCConf allows you to configure it there, and then creates a non-running config, then that sounds like a bug.
However, if you are manually adding backlash comp to the INI then it doesn't seem too unreasonable to have to make changes in more than one place.
- BruceSherry
27 Oct 2016 03:14 #82127
by BruceSherry
Replied by BruceSherry on topic PncConf and backlash
That was adding in the backlash from inside PnCConf, and it does create a non-running config.
I have backlash set on X and Y, both of which don't get the STEPGEN terms, but on Z, which doesn't have backlash configured,it generates them properly.
28 Oct 2016 11:36 #82170
It might be worth raising it as a bug on the tracker:
github.com/LinuxCNC/linuxcnc/issues
28 Oct 2016 11:36 #82171
(I assume that you have hand-edited your config and are now running?)
- BruceSherry
29 Oct 2016 20:33 #82241
by BruceSherry
I suppose I should register for the GITHUB, but I haven't.
I have edited the .ini file, such that the machine works, just in time for a 7i76 to show up, and require that I do everything all over again.
Time to create page: 0.155 seconds
