- Configuring LinuxCNC
- PnCConf Wizard
- [SOLVED] 5i25 wrong mesaflash release generate flashing of INIT led
16 Jun 2017 17:30 - 16 Jun 2017 17:41 #94605
by bkt
Replied by bkt on topic mesa 7i77 & 5i25 not see the pin ... ... INIT led after 07-05-2017 firm install
ok now I can install the right bit file from my ubu16 pc...... but the config not wont to start:
these the backtrace:
this my print.txt
whats happens?
giorgio
jo@jo56:~/linuxcnc-dev/src$ linuxcnc
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/jo/linuxcnc-dev/configs/giorgio1'
Machine configuration file is 'giorgio1.ini'
Starting LinuxCNC...
Found file(REL): ./giorgio1.hal
Note: Using POSIX realtime
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:04:00.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
note: MAXV max: 950.000 units/sec 57000.000 units/min
note: LJOG max: 950.000 units/sec 57000.000 units/min
note: LJOG default: 500.000 units/sec 30000.000 units/min
note: AJOG max: 220.000 units/sec 13200.000 units/min
note: AJOG default: 180.000 units/sec 10800.000 units/min
waiting for s.joints<0>, s.kinematics_type<0>
/home/jo/linuxcnc-dev/bin/milltask (pid 3701) died on signal 11, backtrace stored in /tmp/backtrace.3701
/home/jo/linuxcnc-dev/bin/milltask exiting
<commandline>:0: milltask exited without becoming ready
halui: emcCommandSend: no echo from Task after 5.000 seconds
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
Running HAL shutdown script
hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
hm2/hm2_5i25.0: unregistered
RTAPI_PCI: Unmapped 65536 bytes at 0x7ff5c5162000
hm2_pci: driver unloaded
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
/home/jo/linuxcnc_debug.txt
and
/home/jo/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Could not attach to process. If your uid matches the uid of the target
process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
again as the root user. For more details, see /etc/sysctl.d/10-ptrace.conf
ptrace: Operazione non permessa.
/home/jo/linuxcnc-dev/configs/giorgio1/3701: File o directory non esistente.
No thread selected
No stack.
this my print.txt
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/jo/linuxcnc-dev/bin
LINUXCNC_TCL_DIR=/home/jo/linuxcnc-dev/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/jo/linuxcnc-dev/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/jo/linuxcnc-dev/src/objects
INIVAR=inivar
HALCMD=halcmd
INIFILE=/home/jo/linuxcnc-dev/configs/giorgio1/giorgio1.ini
VERSION=1.0
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z A
KINEMATICS=trivkins
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=5347
whats happens?
giorgio
Last edit: 16 Jun 2017 17:41 by bkt.
16 Jun 2017 17:42 #94608
Replied by PCW on topic mesa 7i77 & 5i25 not see the pin ... ... INIT led after 07-05-2017 firm install
The error:
Is not related to the I/O hardware, you might look at the backtrace or dmesg for more clues to why milltask crashed
Note that there are a number of LinuxCNC things that do not work properly with 16.04, at the minimum
I would run the latest 2.7 LinuxCNC version (2.7.9) or master
16 Jun 2017 17:44 #94609
Yes, there are a number of permission issues on 16.04, these _may_ be fixed on 2.7.9 but I'm not sure
They are (at least mostly) fixed in master
The following user(s) said Thank You: bkt
16 Jun 2017 18:10 #94611
by bkt
ok --- but running my config on axis-gui the intro show 2.8.0-pre1 ... and today I've downlod from git master branch ....
I make an error about ubu version : really is a 14.04 kernel 4.8.15 rt10 ... and probabily I make an other error .. last time on these pc I've install on linuxcnc-dev folder today on linuxcnc-dev/src ....but the config folder is on linuxcnc-dev ...
any how you can suggest me a better release with that kernel? So I can remove the old and install the best one
giorgio
giorgio
16 Jun 2017 18:15 #94613
Is it possible you didn't build LinuxCNC properly? (especially the "sudo make suid" step
16 Jun 2017 18:32 - 16 Jun 2017 18:42 #94617
by bkt
no every step ... only 4 warning on compile step ... previously I have an error from hy_vdf.c file causing from libmodbus timeout calling ... so I correct the file and re install again...
So for greater security I want to delete everything and reinstall ... what do you suggest 2.7.8? Or master is still the best?
p.s. Actually I delete the linuxcnc-dev folder than I use sudo apt-get purge linuxcnc* command and it return:
impossible to find linuxcnc_2.8.0~pre1_amd64.build
so for shure I've not Lcnc install on these pc .... If you tell me it's better to stay on master, then install master, otherwise install the version that you suggest ... rest waiting ... at least if there are problems will not be from the mesa card.
Apart from what you think of the latency on the published histogram? Is it good enough for a servo system?
giorgio
giorgio
Last edit: 16 Jun 2017 18:42 by bkt.
16 Jun 2017 19:09 #94620
You should be able to run 2.7.9 (latest release) or 2.8.0 (master) on Ubuntu 14.04 without any issues (I've run this combo for a year or so until I upgraded it to 16.04) 16.04 works but has some minor things that don't work
You do of course need to build the uspace version when using a Preempt-RT kernel
Latency really doesn't matter much on servo systems or hardware step/dir systems
100 usec latency should be fine, and more can be tolerated with the correct firmware
(up to about 1/2 of the servo thread period = 500 usec)
You have to have a pretty bad real time system to have 500 usec latency
16 Jun 2017 19:45 #94622
by bkt
sorry a minor question ... have you run mesa fpga card over vxworks recently?
said these ...
for the support today.
(Another day of work that will end at 24 o'clock ... )
giorgio
said these ...
giorgio
- PnCConf Wizard
Time to create page: 0.403 seconds
