PnCConf with MESA 5i25 + 7i76 + 7i85
16 Dec 2018 15:30 #122476
Replied by PCW on topic PnCConf with MESA 5i25 + 7i76 + 7i85
The command to write new firmware would be:
sudo mesaflash --device 5i25 --write 5i25_7i76_7i85s.bit
You can run
mesaflash --help
to get a list of mesaflash commands
If the current firmware does not support --reload, you must power cycle the host PC to load the newly written firmware
You can run
mesaflash --help
05 Mar 2019 05:38 #127753
by Peter
Replied by Peter on topic PnCConf with MESA 5i25 + 7i76 + 7i85
Hi Jan and all.
Did you get anywhere with your scales?
I've got the same cards and am about to get the scales going.
Do you or anyone have code relevant to encoders on a 7i85?
05 Mar 2019 11:44 #127778
by pl7i92
Replied by pl7i92 on topic PnCConf with MESA 5i25 + 7i76 + 7i85
you may first see if pins are present by
sudo dmesg -c {You will be asked for a password}
halrun
loadrt hostmot2
loadrt hm2_pci
show pin
show param
exit
dmesg
05 Mar 2019 17:13 - 05 Mar 2019 17:24 #127804
by Peter
HI Yes it all seems to be there
THANKS!
Whats next?
-Peter
THANKS!
Whats next?
-Peter
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
5 u32 IN 0x00000000 hm2_5i25.0.7i73.0.1.display
5 s32 OUT 0 hm2_5i25.0.7i73.0.1.enc0.count
5 bit I/O FALSE hm2_5i25.0.7i73.0.1.enc0.index-enable
5 float OUT 0 hm2_5i25.0.7i73.0.1.enc0.position
5 s32 OUT 0 hm2_5i25.0.7i73.0.1.enc0.rawcounts
5 bit I/O FALSE hm2_5i25.0.7i73.0.1.enc0.reset
5 s32 OUT 0 hm2_5i25.0.7i73.0.1.enc1.count
5 bit I/O FALSE hm2_5i25.0.7i73.0.1.enc1.index-enable
5 float OUT 0 hm2_5i25.0.7i73.0.1.enc1.position
5 s32 OUT 0 hm2_5i25.0.7i73.0.1.enc1.rawcounts
5 bit I/O FALSE hm2_5i25.0.7i73.0.1.enc1.reset
5 s32 OUT 0 hm2_5i25.0.7i73.0.1.enc2.count
5 bit I/O FALSE hm2_5i25.0.7i73.0.1.enc2.index-enable
5 float OUT 0 hm2_5i25.0.7i73.0.1.enc2.position
5 s32 OUT 0 hm2_5i25.0.7i73.0.1.enc2.rawcounts
5 bit I/O FALSE hm2_5i25.0.7i73.0.1.enc2.reset
5 s32 OUT 0 hm2_5i25.0.7i73.0.1.enc3.count
5 bit I/O FALSE hm2_5i25.0.7i73.0.1.enc3.index-enable
5 float OUT 0 hm2_5i25.0.7i73.0.1.enc3.position
5 s32 OUT 0 hm2_5i25.0.7i73.0.1.enc3.rawcounts
5 bit I/O FALSE hm2_5i25.0.7i73.0.1.enc3.reset
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-00
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-00-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-01
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-01-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-02
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-02-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-03
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-03-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-04
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-04-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-05
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-05-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-06
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-06-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-07
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-07-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-08
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-08-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-09
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-09-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-10
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-10-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-11
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-11-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-12
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-12-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-13
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-13-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-14
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-14-not
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-15
5 bit OUT FALSE hm2_5i25.0.7i73.0.1.input-15-not
5 u32 OUT 0x00000000 hm2_5i25.0.7i73.0.1.keycode
5 bit IN FALSE hm2_5i25.0.7i73.0.1.output-00
5 bit IN FALSE hm2_5i25.0.7i73.0.1.output-01
5 bit IN FALSE hm2_5i25.0.7i73.0.1.output-02
5 bit IN FALSE hm2_5i25.0.7i73.0.1.output-03
5 bit IN FALSE hm2_5i25.0.7i73.0.1.output-04
5 bit IN FALSE hm2_5i25.0.7i73.0.1.output-05
5 bit IN FALSE hm2_5i25.0.7i73.0.1.output-06
5 bit IN FALSE hm2_5i25.0.7i73.0.1.output-07
5 bit IN FALSE hm2_5i25.0.7i73.0.1.output-08
5 bit IN FALSE hm2_5i25.0.7i73.0.1.output-09
5 s32 OUT 0 hm2_5i25.0.encoder.00.count
5 s32 OUT 0 hm2_5i25.0.encoder.00.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.00.index-enable
5 bit OUT FALSE hm2_5i25.0.encoder.00.input-a
5 bit OUT FALSE hm2_5i25.0.encoder.00.input-b
5 bit OUT TRUE hm2_5i25.0.encoder.00.input-index
5 bit IN FALSE hm2_5i25.0.encoder.00.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.00.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.00.position
5 float OUT 0 hm2_5i25.0.encoder.00.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.00.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.00.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.00.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.00.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.00.reset
5 float OUT 0 hm2_5i25.0.encoder.00.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.01.count
5 s32 OUT 0 hm2_5i25.0.encoder.01.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.01.index-enable
5 bit OUT FALSE hm2_5i25.0.encoder.01.input-a
5 bit OUT FALSE hm2_5i25.0.encoder.01.input-b
5 bit OUT TRUE hm2_5i25.0.encoder.01.input-index
5 bit IN FALSE hm2_5i25.0.encoder.01.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.01.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.01.position
5 float OUT 0 hm2_5i25.0.encoder.01.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.01.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.01.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.01.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.01.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.01.reset
5 float OUT 0 hm2_5i25.0.encoder.01.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.02.count
5 s32 OUT 0 hm2_5i25.0.encoder.02.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.02.index-enable
5 bit OUT FALSE hm2_5i25.0.encoder.02.input-a
5 bit OUT TRUE hm2_5i25.0.encoder.02.input-b
5 bit OUT FALSE hm2_5i25.0.encoder.02.input-index
5 bit IN FALSE hm2_5i25.0.encoder.02.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.02.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.02.position
5 float OUT 0 hm2_5i25.0.encoder.02.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.02.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.02.quad-error-enable
5 s32 OUT 1 hm2_5i25.0.encoder.02.rawcounts
5 s32 OUT 1 hm2_5i25.0.encoder.02.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.02.reset
5 float OUT 0 hm2_5i25.0.encoder.02.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.03.count
5 s32 OUT 0 hm2_5i25.0.encoder.03.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.03.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.03.input-a
5 bit OUT FALSE hm2_5i25.0.encoder.03.input-b
5 bit OUT TRUE hm2_5i25.0.encoder.03.input-index
5 bit IN FALSE hm2_5i25.0.encoder.03.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.03.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.03.position
5 float OUT 0 hm2_5i25.0.encoder.03.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.03.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.03.quad-error-enable
5 s32 OUT 1 hm2_5i25.0.encoder.03.rawcounts
5 s32 OUT 1 hm2_5i25.0.encoder.03.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.03.reset
5 float OUT 0 hm2_5i25.0.encoder.03.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.04.count
5 s32 OUT 0 hm2_5i25.0.encoder.04.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.04.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.04.input-a
5 bit OUT TRUE hm2_5i25.0.encoder.04.input-b
5 bit OUT TRUE hm2_5i25.0.encoder.04.input-index
5 bit IN FALSE hm2_5i25.0.encoder.04.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.04.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.04.position
5 float OUT 0 hm2_5i25.0.encoder.04.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.04.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.04.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.04.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.04.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.04.reset
5 float OUT 0 hm2_5i25.0.encoder.04.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.05.count
5 s32 OUT 0 hm2_5i25.0.encoder.05.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.05.index-enable
5 bit OUT FALSE hm2_5i25.0.encoder.05.input-a
5 bit OUT FALSE hm2_5i25.0.encoder.05.input-b
5 bit OUT TRUE hm2_5i25.0.encoder.05.input-index
5 bit IN FALSE hm2_5i25.0.encoder.05.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.05.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.05.position
5 float OUT 0 hm2_5i25.0.encoder.05.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.05.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.05.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.05.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.05.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.05.reset
5 float OUT 0 hm2_5i25.0.encoder.05.velocity
5 u32 IN 0x007F2815 hm2_5i25.0.encoder.muxed-sample-frequency
5 bit OUT FALSE hm2_5i25.0.gpio.000.in
5 bit OUT TRUE hm2_5i25.0.gpio.000.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.001.in
5 bit OUT TRUE hm2_5i25.0.gpio.001.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.002.in
5 bit OUT TRUE hm2_5i25.0.gpio.002.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.003.in
5 bit OUT TRUE hm2_5i25.0.gpio.003.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.004.in
5 bit OUT TRUE hm2_5i25.0.gpio.004.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.005.in
5 bit OUT TRUE hm2_5i25.0.gpio.005.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.006.in
5 bit OUT TRUE hm2_5i25.0.gpio.006.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.007.in
5 bit OUT TRUE hm2_5i25.0.gpio.007.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.008.in
5 bit OUT TRUE hm2_5i25.0.gpio.008.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.009.in
5 bit OUT TRUE hm2_5i25.0.gpio.009.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.010.in
5 bit OUT FALSE hm2_5i25.0.gpio.010.in_not
5 bit IN FALSE hm2_5i25.0.gpio.010.out
5 bit OUT FALSE hm2_5i25.0.gpio.011.in
5 bit OUT TRUE hm2_5i25.0.gpio.011.in_not
5 bit IN FALSE hm2_5i25.0.gpio.011.out
5 bit OUT TRUE hm2_5i25.0.gpio.012.in
5 bit OUT FALSE hm2_5i25.0.gpio.012.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.013.in
5 bit OUT FALSE hm2_5i25.0.gpio.013.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.014.in
5 bit OUT TRUE hm2_5i25.0.gpio.014.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.015.in
5 bit OUT TRUE hm2_5i25.0.gpio.015.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.016.in
5 bit OUT TRUE hm2_5i25.0.gpio.016.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.017.in
5 bit OUT FALSE hm2_5i25.0.gpio.017.in_not
5 bit IN FALSE hm2_5i25.0.gpio.017.out
5 bit OUT TRUE hm2_5i25.0.gpio.018.in
5 bit OUT FALSE hm2_5i25.0.gpio.018.in_not
5 bit IN FALSE hm2_5i25.0.gpio.018.out
5 bit OUT TRUE hm2_5i25.0.gpio.019.in
5 bit OUT FALSE hm2_5i25.0.gpio.019.in_not
5 bit IN FALSE hm2_5i25.0.gpio.019.out
5 bit OUT TRUE hm2_5i25.0.gpio.020.in
5 bit OUT FALSE hm2_5i25.0.gpio.020.in_not
5 bit IN FALSE hm2_5i25.0.gpio.020.out
5 bit OUT TRUE hm2_5i25.0.gpio.021.in
5 bit OUT FALSE hm2_5i25.0.gpio.021.in_not
5 bit IN FALSE hm2_5i25.0.gpio.021.out
5 bit OUT TRUE hm2_5i25.0.gpio.022.in
5 bit OUT FALSE hm2_5i25.0.gpio.022.in_not
5 bit IN FALSE hm2_5i25.0.gpio.022.out
5 bit OUT TRUE hm2_5i25.0.gpio.023.in
5 bit OUT FALSE hm2_5i25.0.gpio.023.in_not
5 bit IN FALSE hm2_5i25.0.gpio.023.out
5 bit OUT TRUE hm2_5i25.0.gpio.024.in
5 bit OUT FALSE hm2_5i25.0.gpio.024.in_not
5 bit IN FALSE hm2_5i25.0.gpio.024.out
5 bit OUT TRUE hm2_5i25.0.gpio.025.in
5 bit OUT FALSE hm2_5i25.0.gpio.025.in_not
5 bit IN FALSE hm2_5i25.0.gpio.025.out
5 bit OUT TRUE hm2_5i25.0.gpio.026.in
5 bit OUT FALSE hm2_5i25.0.gpio.026.in_not
5 bit IN FALSE hm2_5i25.0.gpio.026.out
5 bit OUT TRUE hm2_5i25.0.gpio.027.in
5 bit OUT FALSE hm2_5i25.0.gpio.027.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.028.in
5 bit OUT FALSE hm2_5i25.0.gpio.028.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.029.in
5 bit OUT TRUE hm2_5i25.0.gpio.029.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.030.in
5 bit OUT TRUE hm2_5i25.0.gpio.030.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.031.in
5 bit OUT TRUE hm2_5i25.0.gpio.031.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.032.in
5 bit OUT TRUE hm2_5i25.0.gpio.032.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.033.in
5 bit OUT TRUE hm2_5i25.0.gpio.033.in_not
5 bit IN FALSE hm2_5i25.0.led.CR01
5 bit IN FALSE hm2_5i25.0.led.CR02
5 s32 OUT 0 hm2_5i25.0.read.time
5 s32 OUT 0 hm2_5i25.0.read_gpio.time
5 u32 OUT 0x00000000 hm2_5i25.0.sserial.port-0.fault-count
5 u32 OUT 0x00000000 hm2_5i25.0.sserial.port-0.port_state
5 bit IN TRUE hm2_5i25.0.sserial.port-0.run
5 bit IN FALSE hm2_5i25.0.stepgen.00.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.00.counts
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.00.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.00.enable
5 float IN 0 hm2_5i25.0.stepgen.00.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.00.position-fb
5 float IN 0 hm2_5i25.0.stepgen.00.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.00.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.01.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.01.counts
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.01.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.01.enable
5 float IN 0 hm2_5i25.0.stepgen.01.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.01.position-fb
5 float IN 0 hm2_5i25.0.stepgen.01.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.01.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.02.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.02.counts
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.02.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.02.enable
5 float IN 0 hm2_5i25.0.stepgen.02.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.02.position-fb
5 float IN 0 hm2_5i25.0.stepgen.02.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.02.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.03.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.03.counts
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.03.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.03.enable
5 float IN 0 hm2_5i25.0.stepgen.03.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.03.position-fb
5 float IN 0 hm2_5i25.0.stepgen.03.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.03.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.04.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.04.counts
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.04.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.04.enable
5 float IN 0 hm2_5i25.0.stepgen.04.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.04.position-fb
5 float IN 0 hm2_5i25.0.stepgen.04.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.04.velocity-fb
5 bit I/O FALSE hm2_5i25.0.watchdog.has_bit
5 s32 OUT 0 hm2_5i25.0.write.time
5 s32 OUT 0 hm2_5i25.0.write_gpio.time
halcmd: show param
Parameters:
5 u32 RW 0x00000100 hm2_5i25.0.7i73.0.1.enc0.counts-per-rev
5 float RW 1 hm2_5i25.0.7i73.0.1.enc0.scale
5 u32 RW 0x00000100 hm2_5i25.0.7i73.0.1.enc1.counts-per-rev
5 float RW 1 hm2_5i25.0.7i73.0.1.enc1.scale
5 u32 RW 0x00000100 hm2_5i25.0.7i73.0.1.enc2.counts-per-rev
5 float RW 1 hm2_5i25.0.7i73.0.1.enc2.scale
5 u32 RW 0x00000100 hm2_5i25.0.7i73.0.1.enc3.counts-per-rev
5 float RW 1 hm2_5i25.0.7i73.0.1.enc3.scale
5 u32 RO 0x00008000 hm2_5i25.0.7i73.0.1.nvanalogfilter
5 u32 RO 0x00000009 hm2_5i25.0.7i73.0.1.nvbaudrate
5 u32 RO 0x00002710 hm2_5i25.0.7i73.0.1.nvcontrast
5 u32 RO 0x00000414 hm2_5i25.0.7i73.0.1.nvdispmode
5 u32 RO 0x00000000 hm2_5i25.0.7i73.0.1.nvencmode0
5 u32 RO 0x00000000 hm2_5i25.0.7i73.0.1.nvencmode1
5 u32 RO 0x00000000 hm2_5i25.0.7i73.0.1.nvencmode2
5 u32 RO 0x00000000 hm2_5i25.0.7i73.0.1.nvencmode3
5 u32 RO 0x0000001E hm2_5i25.0.7i73.0.1.nvkeytimer
5 u32 RO 0x1300011C hm2_5i25.0.7i73.0.1.nvunitnumber
5 u32 RO 0x00000032 hm2_5i25.0.7i73.0.1.nvwatchdogtimeout
5 bit RW FALSE hm2_5i25.0.7i73.0.1.output-00-invert
5 bit RW FALSE hm2_5i25.0.7i73.0.1.output-01-invert
5 bit RW FALSE hm2_5i25.0.7i73.0.1.output-02-invert
5 bit RW FALSE hm2_5i25.0.7i73.0.1.output-03-invert
5 bit RW FALSE hm2_5i25.0.7i73.0.1.output-04-invert
5 bit RW FALSE hm2_5i25.0.7i73.0.1.output-05-invert
5 bit RW FALSE hm2_5i25.0.7i73.0.1.output-06-invert
5 bit RW FALSE hm2_5i25.0.7i73.0.1.output-07-invert
5 bit RW FALSE hm2_5i25.0.7i73.0.1.output-08-invert
5 bit RW FALSE hm2_5i25.0.7i73.0.1.output-09-invert
5 u32 RO 0x0000000E hm2_5i25.0.7i73.0.1.swrevision
5 bit RW FALSE hm2_5i25.0.encoder.00.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.00.filter
5 bit RW FALSE hm2_5i25.0.encoder.00.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.00.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.00.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.00.scale
5 float RW 0.5 hm2_5i25.0.encoder.00.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.01.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.01.filter
5 bit RW FALSE hm2_5i25.0.encoder.01.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.01.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.01.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.01.scale
5 float RW 0.5 hm2_5i25.0.encoder.01.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.02.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.02.filter
5 bit RW FALSE hm2_5i25.0.encoder.02.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.02.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.02.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.02.scale
5 float RW 0.5 hm2_5i25.0.encoder.02.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.03.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.03.filter
5 bit RW FALSE hm2_5i25.0.encoder.03.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.03.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.03.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.03.scale
5 float RW 0.5 hm2_5i25.0.encoder.03.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.04.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.04.filter
5 bit RW FALSE hm2_5i25.0.encoder.04.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.04.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.04.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.04.scale
5 float RW 0.5 hm2_5i25.0.encoder.04.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.05.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.05.filter
5 bit RW FALSE hm2_5i25.0.encoder.05.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.05.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.05.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.05.scale
5 float RW 0.5 hm2_5i25.0.encoder.05.vel-timeout
5 bit RW FALSE hm2_5i25.0.gpio.000.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.000.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.001.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.001.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.002.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.002.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.003.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.003.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.004.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.004.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.005.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.005.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.006.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.006.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.007.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.007.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.008.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.008.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.009.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.009.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.010.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.010.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.010.is_output
5 bit RW FALSE hm2_5i25.0.gpio.011.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.011.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.011.is_output
5 bit RW FALSE hm2_5i25.0.gpio.012.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.012.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.017.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.017.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.017.is_output
5 bit RW FALSE hm2_5i25.0.gpio.018.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.018.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.018.is_output
5 bit RW FALSE hm2_5i25.0.gpio.019.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.019.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.019.is_output
5 bit RW FALSE hm2_5i25.0.gpio.020.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.020.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.020.is_output
5 bit RW FALSE hm2_5i25.0.gpio.021.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.021.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.021.is_output
5 bit RW FALSE hm2_5i25.0.gpio.022.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.022.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.022.is_output
5 bit RW FALSE hm2_5i25.0.gpio.023.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.023.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.023.is_output
5 bit RW FALSE hm2_5i25.0.gpio.024.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.024.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.024.is_output
5 bit RW FALSE hm2_5i25.0.gpio.025.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.025.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.025.is_output
5 bit RW FALSE hm2_5i25.0.gpio.026.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.026.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.026.is_output
5 bit RW FALSE hm2_5i25.0.gpio.027.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.027.is_opendrain
5 bit RW FALSE hm2_5i25.0.io_error
5 s32 RW 0 hm2_5i25.0.read.tmax
5 bit RO FALSE hm2_5i25.0.read.tmax-increased
5 s32 RW 0 hm2_5i25.0.read_gpio.tmax
5 bit RO FALSE hm2_5i25.0.read_gpio.tmax-increased
5 u32 RW 0x00000001 hm2_5i25.0.sserial.port-0.fault-dec
5 u32 RW 0x0000000A hm2_5i25.0.sserial.port-0.fault-inc
5 u32 RW 0x000000C8 hm2_5i25.0.sserial.port-0.fault-lim
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.00.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.00.maxvel
5 float RW 1 hm2_5i25.0.stepgen.00.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.01.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.01.maxvel
5 float RW 1 hm2_5i25.0.stepgen.01.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.02.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.02.maxvel
5 float RW 1 hm2_5i25.0.stepgen.02.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.03.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.03.maxvel
5 float RW 1 hm2_5i25.0.stepgen.03.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.04.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.04.maxvel
5 float RW 1 hm2_5i25.0.stepgen.04.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-3
5 u32 RW 0x004C4B40 hm2_5i25.0.watchdog.timeout_ns
5 s32 RW 0 hm2_5i25.0.write.tmax
5 bit RO FALSE hm2_5i25.0.write.tmax-increased
5 s32 RW 0 hm2_5i25.0.write_gpio.tmax
5 bit RO FALSE hm2_5i25.0.write_gpio.tmax-increased
halcmd:
Last edit: 05 Mar 2019 17:24 by andypugh.
05 Mar 2019 17:18 - 06 Mar 2019 13:33 #127807
by Peter
heres the output from dmesg
cnc@CNCMILL:~$ dmesg
[ 265.087381] I-pipe: head domain RTAI registered.
[ 265.087387] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 265.087426] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 265.087429] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 2393909000, CPU_FREQ 2393909000
[ 265.087432] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 265.087435] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 10591250
[ 265.105746] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 265.105793] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 265.105798] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 265.105801] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393909000 hz.
[ 265.105804] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 265.121707] RTAI[math]: loaded.
[ 280.420366] hm2: loading Mesa HostMot2 driver version 0.15
[ 298.531635] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 298.531683] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 298.534215] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 298.590659] Board hm2_5i25.0.7i73.0.1 Hardware Mode 0 = nokeyboardnodisplay
[ 298.592245] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoder
[ 298.594157] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalog
[ 298.596093] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalog
[ 298.597599] Board hm2_5i25.0.7i73.0.1 Hardware Mode 1 = nokeyboarddisplay
[ 298.599570] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplay
[ 298.601930] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplay
[ 298.604521] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplay
[ 298.606266] Board hm2_5i25.0.7i73.0.1 Hardware Mode 2 = keyboard4by8nodisplay
[ 298.608498] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoderkeycode4by8
[ 298.611078] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogkeycode4by8
[ 298.613666] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogkeycode4by8
[ 298.615280] Board hm2_5i25.0.7i73.0.1 Hardware Mode 3 = keyboard4by8display
[ 298.617929] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplaykeycode4by8
[ 298.620938] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplaykeycode4by8
[ 298.624187] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplaykeycode4by8
[ 298.625920] Board hm2_5i25.0.7i73.0.1 Hardware Mode 4 = keyboard8by8nodisplay
[ 298.628152] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoderkeycode8by8
[ 298.630732] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogkeycode8by8
[ 298.633309] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogkeycode8by8
[ 298.634922] Board hm2_5i25.0.7i73.0.1 Hardware Mode 5 = keyboard8by8display
[ 298.637583] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplaykeycode8by8
[ 298.640580] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplaykeycode8by8
[ 298.643806] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplaykeycode8by8
[ 298.760693] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 298.760698] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 298.760701] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 298.760704] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 298.760706] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 298.760709] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 298.760712] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 298.760714] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
[ 298.760717] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
[ 298.760720] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
[ 298.760723] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
[ 298.760725] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 298.760727] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 298.760730] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Smart Serial Interface #0, pin TxData1 (Output)
[ 298.760733] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Smart Serial Interface #0, pin RxData1 (Input)
[ 298.760736] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #0, pin Muxed Index (Input)
[ 298.760738] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #0, pin Muxed B (Input)
[ 298.760741] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #0, pin Muxed A (Input)
[ 298.760744] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 298.760746] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 298.760748] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 298.760750] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 298.760752] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 298.760754] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 298.760756] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 298.760758] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 298.760760] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 298.760762] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 298.760765] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder Select #2, pin Mux Select 0 (Output)
[ 298.760768] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 298.760770] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 298.760773] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 298.760776] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 298.760778] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 298.760781] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 298.760875] hm2/hm2_5i25.0: registered
[ 298.760878] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 1005.398790] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 1005.398796] hm2/hm2_5i25.0: unregistered
[ 1005.398859] hm2_pci: driver unloaded
[ 1005.400828] hm2: unloading
[ 1005.450866] RTAI[math]: unloaded.
[ 1005.452939] SCHED releases registered named ALIEN PEDV$D
[ 1005.458863] RTAI[malloc]: unloaded.
[ 1005.556014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1005.557976] I-pipe: head domain RTAI unregistered.
[ 1005.558015] RTAI[hal]: unmounted.
cnc@CNCMILL:~$
Last edit: 06 Mar 2019 13:33 by Peter.
09 Mar 2019 01:52 #128122
by Peter
Hi Everyone, I am trying to get scales going on a 7i85.
my last 2 posts are the outputs from show pin and dmesg.
upon review I am confused by the output.
show pin shows encoders 0-5 on the 5i25. though the 7i85 has 4 and the 7i76 has 1
also the output from dmesg seems to show 3.
I am sure this is just me though I am stuck.
any help much appreciated,
-Peter
-Peter
09 Mar 2019 03:02 #128125
The reason there are 6 encoders is that LinuxCNCs hm2 driver cannot mix encoder types, and since the 7I85S needs muxed encoders, the 7I76 must used muxed encoders This means that you end up with a dummy encoder (encoder 1) that duplicates encoder 0 on the 7I76 (the 7I85S has encoders 2 through 5)
09 Mar 2019 03:07 #128126
by Peter
Hi and thanks for that.
I have the non "S" variant of the 7i85 though I assume the same can be said?
do you have any insight in why dmesg only reports 3?
can you point me to any resources regarding next steps for reading the scales?
-Peter
-Peter
09 Mar 2019 03:48 #128128
Yes the encoder part of the 7I85 is the same as the 7I85S
Dmesg reports the pins for 3 multiplexed encoders (each set of pins for a
muxed encoder supports 2 actual encoders)
What are your intentions for the scales?
Even if you intend to use the scales in the final configuration, I would start with a standard step/dir configuration and get it working before proceeding
09 Mar 2019 04:00 #128129
by Peter
That sounds reasonable, I have moved the motors in the test/tune axis configuration screens.
I am hoping to use the mill in a sort of power feed and DRO configuration most of the time, with occasional CNCing.
If possible I would like eventually to get a PID loop going.
Not for lost steps, as much as some backlash compensation
Time to create page: 0.169 seconds
