odd error message popping up for missing GST file?
12 May 2018 21:17 #110620
by Lcvette
odd error message popping up for missing GST file? was created by Lcvette
hello all, I am getting an odd message window popping up saying im missing a GST file? and i'm not certain what to do about it. looking for some suggestions or thoughts, i tried to dig into it with the little skills I currently posses but its a bit beyond my level and i am hoping for some experience or knowledge that may help resolve it. i have a couple different config files made so far but this one is the primary one i will need to use as it has the ATC functionality in it from a friend and i'm not certain how to get around it. I have attached a screenshot of the error message as well as the file it appears to be looking at when it triggers, not certain if that is helpful at all or not. please let me know if there is anything else i can provide!
Thank you very much in advance!
Chris
Chris
13 May 2018 03:12 #110633
Replied by cmorley on topic odd error message popping up for missing GST file?
as you have found gst is for sounds.
It's a known problem.
What distribution are you using and what version of linuxcnc?
Chris M
Chris M
The following user(s) said Thank You: Lcvette
13 May 2018 03:36 #110635
by Lcvette
Replied by Lcvette on topic odd error message popping up for missing GST file?
cmorley,
I'm running the Preempt RT Stretch Debian? linuxcnc install for amd64 from the download link below:
www.linuxcnc.org/testing-stretch-rtpreempt/
13 May 2018 03:43 #110636
you need the package
python-gst0.10
not sure that is available in stretch.
Norbert has't updated Gmoccapy to use the newer python-gst-1.0 yet.
Chris M
python-gst0.10
Chris M
13 May 2018 03:50 #110637
by Lcvette
Ah, ok, would that be done as follows?
sudo apt-get install python-gst0.10
13 May 2018 03:58 #110638
If the package is available from normal repositories that will work... if not you may need to try other things.
or try replacing the file with this;
13 May 2018 03:59 #110639
with that file you wont get sound but shouldn't get an error - tough I didn't actually test it.
Chris M
Chris M
13 May 2018 04:34 - 15 May 2018 23:40 #110643
by Lcvette
wow, so that file was a major break through for me Mr. cmorley! i cannot thank you enough. not all the way home yet, but my config file somewhat loaded albeit very slowly and with no functionality, but it did have a screen and a new set of debug files to tackle. and i am guessing that they all have something to do with a similar situation as the one you brought to light with the files either being too new or too old, not sure which, and not sure of the solution just yet, but it is something to look into for the moment! so thank you very much! just for giggles i am posting my debug report below in the event you see anything that catches your eye.
Print file information:
RUN_IN_PLACE=no
Debug file information:
Note: Using POSIX realtime
/home/chris/linuxcnc/configs/VMC2/VMC2.ini:121: executing 'import sys
sys.path.append("/home/chris/linuxcnc/configs/VMC2/python")'
PythonPlugin: Python '2.7.13 (default, Nov 24 2017, 17:33:09)
[GCC 6.3.0 20170516]'
NGC file not found: ngc=toolchange - 55:REMAP = M6 modalgroup=6 prolog=change_prolog ngc=toolchange epilog=change_epilog
is_callable(__delete__) = FALSE
/usr/lib/python2.7/dist-packages/gladevcp/hal_mdihistory.py:89: GtkWarning: IA__gtk_tree_path_append_index: assertion 'index >= 0' failed
self.tv.scroll_to_cell(path)
/usr/lib/python2.7/dist-packages/gladevcp/hal_mdihistory.py:89: GtkWarning: IA__gtk_tree_view_scroll_to_cell: assertion 'tree_view->priv->tree != NULL' failed
/usr/lib/python2.7/dist-packages/gladevcp/hal_mdihistory.py:90: GtkWarning: IA__gtk_tree_path_append_index: assertion 'index >= 0' failed
self.tv.set_cursor(path)
/usr/lib/python2.7/dist-packages/gladevcp/hal_mdihistory.py:90: GtkWarning: IA__gtk_tree_row_reference_new_proxy: assertion 'path->depth > 0' failed
/usr/bin/gmoccapy:237: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
/usr/bin/gladevcp:185: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
builder.add_from_file(xmlname)
(gmoccapy:2718): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
/usr/bin/linuxcnc: line 857: 2718 Killed $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
2661
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 1746.038014] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1746.038016] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
Chris M
RUN_IN_PLACE=no
Warning: Spoiler!
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.11
Machine configuration directory is '/home/chris/linuxcnc/configs/VMC2'
Machine configuration file is 'VMC2.ini'
INIFILE=/home/chris/linuxcnc/configs/VMC2/VMC2.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Starting LinuxCNC...
Found file(REL): ./VMC2.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:13:03:d6
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
Board hm2_7i92.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_7i92.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_7i92.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.1 Software Mode 0 = analogout_enables
Board hm2_7i92.0.7i76.0.3 Hardware Mode 0 = standard
Board hm2_7i92.0.7i76.0.3 Software Mode 0 = io_spin
Board hm2_7i92.0.7i76.0.3 Software Mode 1 = io_ana_spin
Board hm2_7i92.0.7i76.0.3 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0: IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0: IO Pin 002 (P2-02): IOPort
hm2/hm2_7i92.0: IO Pin 003 (P2-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_7i92.0: IO Pin 004 (P2-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_7i92.0: IO Pin 005 (P2-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i92.0: IO Pin 006 (P2-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i92.0: IO Pin 007 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i92.0: IO Pin 008 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 009 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 010 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 011 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 012 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 013 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 014 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 015 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 016 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 017 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 018 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 019 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 020 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 021 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 022 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 023 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 024 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 025 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 026 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 027 (P1-07): Smart Serial Interface #0, pin TxData3 (Output)
hm2/hm2_7i92.0: IO Pin 028 (P1-08): Smart Serial Interface #0, pin RxData3 (Input)
hm2/hm2_7i92.0: IO Pin 029 (P1-09): IOPort
hm2/hm2_7i92.0: IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0: IO Pin 031 (P1-11): IOPort
hm2/hm2_7i92.0: IO Pin 032 (P1-12): IOPort
hm2/hm2_7i92.0: IO Pin 033 (P1-13): IOPort
hm2/hm2_7i92.0: registered
Found file(REL): ./custom.hal
Starting DISPLAY program: gmoccapy
emc/task/emctask.cc 389: interp_error: File not open
File not open
emc/task/emctaskmain.cc 3017: can't initialize interpreter
**** probe_screen GETINIINFO ****
Preference file path: gmoccapy_preferences
No option 'chk_set_zero' in section: 'DEFAULT'
No option 'chk_auto_rott' in section: 'DEFAULT'
No option 'ps_searchvel' in section: 'DEFAULT'
No option 'ps_probevel' in section: 'DEFAULT'
No option 'ps_z_clearance' in section: 'DEFAULT'
No option 'ps_probe_max' in section: 'DEFAULT'
No option 'ps_probe_latch' in section: 'DEFAULT'
No option 'ps_probe_diam' in section: 'DEFAULT'
No option 'ps_xy_clearance' in section: 'DEFAULT'
No option 'ps_edge_lenght' in section: 'DEFAULT'
No option 'ps_offs_x' in section: 'DEFAULT'
No option 'ps_offs_y' in section: 'DEFAULT'
No option 'ps_offs_z' in section: 'DEFAULT'
No option 'ps_offs_angle' in section: 'DEFAULT'
Killing task linuxcncsvr, PID=2661
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.11
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
File not open
hm2: unloading
Warning: Spoiler!
2661
Warning: Spoiler!
[ 1746.038019] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1746.038020] Call Trace:
[ 1746.038024] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1746.038027] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1746.038030] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1746.038034] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1746.038037] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1746.038039] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1746.038042] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1746.038049] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1746.038052] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1746.038056] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1746.038059] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1746.038062] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1746.038064] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1746.038066] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1746.038068] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1746.038070] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1746.038073] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1746.038074] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1746.038076] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1746.038079] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1746.038082] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1746.038084] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1748.373833] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1748.373871] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1748.373878] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1748.373883] Preemption disabled at:
[ 1748.373883] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1748.373886] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1748.373887] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1748.373891] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1748.373893] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1748.373894] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1748.373895] Call Trace:
[ 1748.373901] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1748.373903] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1748.373906] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1748.373908] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1748.373910] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1748.373912] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1748.373914] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1748.373921] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1748.373924] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1748.373928] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1748.373930] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1748.373933] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1748.373935] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1748.373936] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1748.373938] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1748.373939] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1748.373941] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1748.373942] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1748.373944] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1748.373946] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1748.373948] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1748.373950] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1749.157768] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1749.157813] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1749.157821] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1749.157828] Preemption disabled at:
[ 1749.157828] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1749.157832] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1749.157833] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1749.157838] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1749.157841] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1749.157843] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1749.157843] Call Trace:
[ 1749.157850] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1749.157853] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1749.157857] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1749.157861] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1749.157863] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1749.157866] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1749.157869] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1749.157877] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1749.157880] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1749.157885] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1749.157888] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1749.157891] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1749.157893] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1749.157895] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1749.157897] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1749.157900] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1749.157902] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1749.157904] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1749.157906] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1749.157909] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1749.157912] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1749.157914] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1759.127956] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1759.128001] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1759.128009] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1759.128016] Preemption disabled at:
[ 1759.128016] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1759.128020] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1759.128021] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1759.128026] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1759.128029] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f41
[ 1759.128031] ffff9bf17ece9a00 0000000000000001 ffff9bf178910fc0 ffffbd3641183bd0
[ 1759.128032] Call Trace:
[ 1759.128039] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1759.128041] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1759.128045] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1759.128049] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1759.128052] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1759.128054] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1759.128057] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1759.128066] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1759.128070] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1759.128074] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1759.128078] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1759.128081] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1759.128083] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1759.128085] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1759.128087] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1759.128090] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1759.128092] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1759.128094] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1759.128097] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1759.128100] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1759.128103] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1759.128105] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.036885] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1764.036930] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.036938] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.036945] Preemption disabled at:
[ 1764.036946] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.036950] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.036951] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.036955] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1764.036958] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1764.036960] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1764.036961] Call Trace:
[ 1764.036968] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.036971] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.036975] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.036978] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.036981] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.036983] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.036986] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.037008] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1764.037020] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1764.037031] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1764.037043] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1764.037046] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1764.037049] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.037052] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.037054] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.037056] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.037058] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.037060] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.037062] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.037064] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.037067] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.037070] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.037072] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.372861] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1764.372905] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.372913] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.372920] Preemption disabled at:
[ 1764.372920] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.372924] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.372925] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.372929] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1764.372932] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1764.372934] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1764.372935] Call Trace:
[ 1764.372941] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.372943] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.372947] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.372950] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.372953] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.372955] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.372958] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.372966] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1764.372970] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1764.372974] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1764.372977] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.372980] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.372983] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.372985] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.372986] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.372989] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.372991] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.372993] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.372995] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1764.372998] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.373001] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.373003] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.468854] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1764.468898] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.468906] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.468913] Preemption disabled at:
[ 1764.468913] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.468917] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.468918] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.468923] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1764.468925] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1764.468927] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1764.468928] Call Trace:
[ 1764.468935] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.468937] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.468941] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.468945] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.468947] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.468950] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.468953] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.468960] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1764.468964] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1764.468968] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1764.468971] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.468974] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.468976] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.468979] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.468980] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.468983] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.468985] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.468987] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.468989] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1764.468992] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.468994] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.468996] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.469036] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1764.469064] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.469069] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.469072] Preemption disabled at:
[ 1764.469072] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.469074] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.469075] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.469078] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1764.469081] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 0000000000000000
[ 1764.469084] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1764.469084] Call Trace:
[ 1764.469087] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.469089] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.469092] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.469095] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.469097] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.469100] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.469103] [<ffffffffbcfe6ba0>] ? dma_pool_free+0x20/0xc0
[ 1764.469106] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.469125] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1764.469137] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1764.469148] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1764.469160] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1764.469163] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1764.469165] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.469168] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.469170] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.469172] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.469174] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.469176] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.469178] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.469180] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.469182] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.469185] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.469187] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1765.604790] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1765.604835] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1765.604843] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1765.604850] Preemption disabled at:
[ 1765.604850] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1765.604854] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1765.604855] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1765.604860] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1765.604862] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1765.604864] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1765.604865] Call Trace:
[ 1765.604873] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1765.604875] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1765.604879] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1765.604882] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1765.604885] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1765.604888] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1765.604890] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1765.604914] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1765.604926] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1765.604938] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1765.604950] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1765.604953] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1765.604956] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1765.604960] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1765.604962] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1765.604964] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1765.604966] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1765.604968] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1765.604970] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1765.604972] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1765.604976] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1765.604979] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1765.604981] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1776.212165] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1776.212210] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1776.212218] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1776.212225] Preemption disabled at:
[ 1776.212225] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1776.212229] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1776.212230] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1776.212234] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1776.212237] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1776.212239] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1776.212240] Call Trace:
[ 1776.212246] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1776.212249] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1776.212252] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1776.212256] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1776.212258] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1776.212261] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1776.212264] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1776.212272] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1776.212276] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1776.212280] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1776.212284] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1776.212288] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1776.212290] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1776.212292] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1776.212294] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1776.212296] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1776.212298] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1776.212300] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1776.212302] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1776.212305] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1776.212308] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1776.212310] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1779.827945] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1779.827990] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1779.827998] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1779.828005] Preemption disabled at:
[ 1779.828005] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1779.828009] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1779.828010] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1779.828015] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1779.828017] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1779.828020] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1779.828020] Call Trace:
[ 1779.828027] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1779.828030] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1779.828033] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1779.828037] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1779.828039] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1779.828042] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1779.828045] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1779.828054] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1779.828057] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1779.828061] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1779.828064] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1779.828068] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1779.828070] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1779.828072] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1779.828074] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1779.828076] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1779.828078] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1779.828080] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1779.828082] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1779.828085] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1779.828088] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1779.828090] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1781.139876] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1781.139921] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1781.139929] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1781.139937] Preemption disabled at:
[ 1781.139937] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1781.139941] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1781.139942] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1781.139947] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133c00
[ 1781.139950] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1781.139952] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c40
[ 1781.139953] Call Trace:
[ 1781.139960] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1781.139963] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1781.139967] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1781.139971] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1781.139973] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1781.139976] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1781.139979] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1781.140004] [<ffffffffc043aec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[ 1781.140015] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1781.140027] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1781.140031] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1781.140033] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1781.140037] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1781.140039] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1781.140041] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1781.140043] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1781.140045] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1781.140048] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1781.140050] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1781.140053] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1781.140056] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1781.140058] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1781.315860] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1781.315902] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1781.315910] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1781.315917] Preemption disabled at:
[ 1781.315917] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1781.315921] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1781.315921] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1781.315926] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1781.315928] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1781.315931] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1781.315931] Call Trace:
[ 1781.315938] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1781.315941] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1781.315945] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1781.315948] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1781.315951] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1781.315954] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1781.315957] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1781.315965] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1781.315968] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1781.315972] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1781.315975] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1781.315979] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1781.315981] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1781.315983] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1781.315985] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1781.315987] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1781.315989] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1781.315991] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1781.315993] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1781.315996] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1781.315999] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1781.316001] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.011770] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.011817] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.011826] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.011833] Preemption disabled at:
[ 1783.011833] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.011837] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.011838] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.011843] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.011845] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.011848] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.011848] Call Trace:
[ 1783.011855] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.011858] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.011862] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.011865] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.011868] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.011871] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.011874] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.011882] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.011887] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.011891] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.011895] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.011899] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.011902] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.011904] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.011907] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.011909] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.011912] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.011914] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.011916] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.011919] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.011922] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.011924] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.107759] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.107796] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.107803] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.107809] Preemption disabled at:
[ 1783.107809] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.107812] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.107813] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.107816] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.107818] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.107820] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.107821] Call Trace:
[ 1783.107826] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.107828] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.107831] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.107834] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.107836] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.107838] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.107840] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.107846] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.107849] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.107852] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.107855] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.107857] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.107859] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.107860] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.107862] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.107863] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.107865] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.107866] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.107868] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.107870] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.107872] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.107874] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.219742] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.219780] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.219786] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.219792] Preemption disabled at:
[ 1783.219792] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.219796] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.219796] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.219800] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.219802] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.219804] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.219804] Call Trace:
[ 1783.219810] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.219812] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.219815] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.219818] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.219820] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.219822] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.219824] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.219830] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.219833] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.219836] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.219839] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.219841] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.219842] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.219844] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.219845] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.219847] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.219849] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.219850] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.219851] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.219854] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.219856] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.219858] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.507721] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.507765] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.507773] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.507781] Preemption disabled at:
[ 1783.507781] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.507785] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.507786] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.507791] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.507793] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.507795] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.507796] Call Trace:
[ 1783.507803] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.507805] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.507809] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.507812] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.507815] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.507817] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.507820] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.507829] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.507832] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.507836] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.507839] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.507843] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.507845] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.507847] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.507849] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.507852] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.507854] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.507856] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.507858] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.507861] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.507864] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.507866] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.747731] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.747779] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.747787] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.747795] Preemption disabled at:
[ 1783.747795] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.747799] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.747800] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.747804] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.747808] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.747810] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.747810] Call Trace:
[ 1783.747818] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.747820] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.747824] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.747828] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.747831] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.747833] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.747836] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.747845] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.747848] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.747853] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.747856] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.747859] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.747862] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.747864] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.747865] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.747868] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.747870] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.747872] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.747874] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.747877] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.747880] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.747883] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.843720] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.843759] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.843766] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.843772] Preemption disabled at:
[ 1783.843772] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.843775] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.843776] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.843779] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.843781] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.843783] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.843783] Call Trace:
[ 1783.843790] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.843792] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.843795] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.843798] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.843799] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.843801] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.843803] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.843810] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.843813] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.843816] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.843819] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.843821] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.843822] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.843824] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.843825] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.843826] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.843828] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.843829] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.843830] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.843832] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.843834] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.843836] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.891708] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.891744] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.891750] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.891756] Preemption disabled at:
[ 1783.891756] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.891758] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.891759] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.891762] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.891764] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.891765] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.891765] Call Trace:
[ 1783.891771] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.891773] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.891775] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.891778] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.891779] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.891781] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.891782] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.891788] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.891791] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.891794] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.891797] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.891799] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.891800] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.891802] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.891803] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.891804] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.891805] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.891806] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.891807] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.891809] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.891811] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.891812] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.923705] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.923741] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.923747] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.923753] Preemption disabled at:
[ 1783.923753] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.923756] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.923757] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.923760] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.923761] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.923763] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.923763] Call Trace:
[ 1783.923769] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.923770] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.923773] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.923776] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.923777] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.923779] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.923780] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.923786] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.923789] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.923791] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.923794] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.923796] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.923798] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.923799] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.923800] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.923801] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.923802] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.923804] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.923805] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.923807] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.923809] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.923810] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.987703] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.987743] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.987749] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.987755] Preemption disabled at:
[ 1783.987756] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.987759] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.987760] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.987763] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.987765] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.987767] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.987767] Call Trace:
[ 1783.987773] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.987775] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.987778] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.987780] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.987782] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.987784] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.987785] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.987792] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.987795] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.987799] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.987802] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.987804] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.987806] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.987807] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.987809] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.987810] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.987812] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.987813] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.987814] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.987817] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.987819] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.987820] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1785.875585] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1785.875630] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1785.875637] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1785.875644] Preemption disabled at:
[ 1785.875645] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1785.875649] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1785.875650] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1785.875655] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1785.875657] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1785.875660] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1785.875661] Call Trace:
[ 1785.875667] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1785.875669] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1785.875673] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1785.875677] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1785.875679] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1785.875682] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1785.875685] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1785.875706] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1785.875717] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1785.875729] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1785.875741] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1785.875744] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1785.875747] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1785.875750] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1785.875753] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1785.875755] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1785.875757] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1785.875759] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1785.875761] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1785.875763] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1785.875767] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1785.875769] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1785.875772] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1786.851550] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1786.851596] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1786.851604] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1786.851611] Preemption disabled at:
[ 1786.851611] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1786.851615] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1786.851616] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1786.851621] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1786.851624] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1786.851626] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1786.851627] Call Trace:
[ 1786.851634] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1786.851637] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1786.851640] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1786.851644] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1786.851647] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1786.851650] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1786.851653] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1786.851661] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1786.851665] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1786.851670] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1786.851673] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1786.851677] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1786.851679] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1786.851681] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1786.851683] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1786.851685] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1786.851688] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1786.851690] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1786.851692] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1786.851696] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1786.851699] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1786.851702] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1793.555146] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1793.555192] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1793.555200] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1793.555209] Preemption disabled at:
[ 1793.555209] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1793.555213] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1793.555215] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1793.555220] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1793.555224] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1793.555226] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1793.555227] Call Trace:
[ 1793.555236] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1793.555238] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1793.555243] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1793.555247] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1793.555250] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1793.555253] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1793.555256] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1793.555265] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1793.555270] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1793.555274] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1793.555278] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1793.555281] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1793.555283] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1793.555285] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1793.555287] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1793.555290] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1793.555292] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1793.555294] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1793.555296] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1793.555299] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1793.555302] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1793.555304] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1795.283023] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1795.283070] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1795.283079] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1795.283086] Preemption disabled at:
[ 1795.283086] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1795.283090] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1795.283091] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1795.283096] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133c00
[ 1795.283098] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1795.283100] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c40
[ 1795.283101] Call Trace:
[ 1795.283108] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1795.283111] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1795.283115] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1795.283119] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1795.283121] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1795.283124] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1795.283127] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1795.283150] [<ffffffffc043aec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[ 1795.283162] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1795.283174] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1795.283177] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1795.283179] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1795.283183] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1795.283185] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1795.283187] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1795.283189] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1795.283191] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1795.283193] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1795.283195] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1795.283198] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1795.283201] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1795.283203] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1797.682890] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1797.682941] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1797.682950] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1797.682956] Preemption disabled at:
[ 1797.682956] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1797.682960] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1797.682960] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1797.682965] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1797.682966] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1797.682968] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1797.682969] Call Trace:
[ 1797.682977] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1797.682978] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1797.682983] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1797.682986] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1797.682988] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1797.682990] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1797.682992] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1797.683002] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1797.683006] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1797.683010] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1797.683013] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1797.683017] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1797.683019] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1797.683021] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1797.683022] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1797.683024] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1797.683025] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1797.683027] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1797.683028] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1797.683033] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1797.683035] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1797.683037] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1797.970865] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1797.970910] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1797.970918] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1797.970925] Preemption disabled at:
[ 1797.970925] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1797.970929] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1797.970930] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1797.970934] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1797.970937] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1797.970939] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1797.970940] Call Trace:
[ 1797.970947] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1797.970950] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1797.970953] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1797.970957] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1797.970959] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1797.970962] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1797.970964] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1797.970973] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1797.970976] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1797.970981] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1797.970984] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1797.970987] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1797.970989] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1797.970991] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1797.970993] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1797.970995] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1797.970997] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1797.970999] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1797.971001] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1797.971004] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1797.971007] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1797.971009] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.810770] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.810816] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.810824] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.810832] Preemption disabled at:
[ 1799.810832] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.810837] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.810838] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.810842] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.810845] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.810847] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.810848] Call Trace:
[ 1799.810855] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.810857] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.810861] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.810864] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.810867] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.810869] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.810872] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.810881] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.810885] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.810889] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.810893] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.810896] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.810898] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.810900] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.810902] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.810904] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.810906] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.810908] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.810910] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.810913] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.810916] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.810918] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.874762] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.874799] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.874804] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.874810] Preemption disabled at:
[ 1799.874810] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.874813] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.874813] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.874817] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.874818] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.874820] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.874820] Call Trace:
[ 1799.874826] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.874827] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.874830] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.874833] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.874834] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.874836] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.874837] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.874844] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.874846] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.874849] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.874852] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.874854] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.874856] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.874857] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.874858] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.874859] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.874860] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.874862] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.874863] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.874865] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.874867] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.874869] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.954748] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.954780] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.954786] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.954792] Preemption disabled at:
[ 1799.954792] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.954795] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.954795] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.954798] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.954800] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.954801] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.954801] Call Trace:
[ 1799.954806] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.954808] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.954810] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.954812] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.954814] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.954815] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.954817] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.954822] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.954825] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.954828] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.954830] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.954832] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.954833] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.954834] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.954835] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.954836] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.954838] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.954839] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.954840] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.954842] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.954843] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.954845] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.970756] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.970791] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.970798] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.970803] Preemption disabled at:
[ 1799.970804] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.970807] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.970807] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.970811] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.970813] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.970814] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.970815] Call Trace:
[ 1799.970821] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.970822] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.970825] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.970828] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.970829] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.970831] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.970833] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.970840] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.970843] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.970846] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.970849] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.970851] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.970853] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.970854] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.970856] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.970857] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.970858] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.970860] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.970861] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.970863] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.970865] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.970867] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.034753] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.034794] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.034802] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.034808] Preemption disabled at:
[ 1800.034808] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.034812] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.034812] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.034816] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.034818] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.034820] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.034820] Call Trace:
[ 1800.034826] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.034828] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.034831] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.034834] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.034836] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.034838] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.034841] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.034848] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.034852] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.034856] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.034859] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.034862] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.034863] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.034865] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.034867] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.034868] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.034870] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.034872] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.034874] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.034877] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.034879] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.034881] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.242729] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.242774] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.242782] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.242789] Preemption disabled at:
[ 1800.242789] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.242794] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.242794] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.242799] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.242802] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.242804] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.242805] Call Trace:
[ 1800.242812] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.242814] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.242818] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.242822] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.242825] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.242827] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.242830] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.242839] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.242842] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.242846] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.242850] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.242853] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.242855] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.242858] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.242860] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.242862] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.242864] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.242866] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.242868] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.242871] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.242874] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.242876] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.594722] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.594770] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.594778] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.594785] Preemption disabled at:
[ 1800.594785] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.594789] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.594790] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.594796] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.594799] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.594801] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.594802] Call Trace:
[ 1800.594809] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.594812] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.594816] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.594819] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.594823] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.594826] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.594829] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.594838] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.594842] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.594847] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.594850] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.594855] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.594857] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.594859] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.594862] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.594864] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.594866] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.594868] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.594871] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.594874] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.594877] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.594879] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.626721] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.626769] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.626777] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.626785] Preemption disabled at:
[ 1800.626785] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.626789] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.626790] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.626795] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.626798] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.626800] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.626801] Call Trace:
[ 1800.626809] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.626811] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.626815] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.626818] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.626821] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.626824] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.626827] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.626836] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.626840] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.626844] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.626848] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.626852] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.626855] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.626857] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.626859] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.626861] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.626864] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.626866] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.626868] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.626872] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.626875] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.626877] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.642707] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.642747] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.642754] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.642761] Preemption disabled at:
[ 1800.642761] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.642764] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.642765] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.642769] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.642771] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.642773] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.642774] Call Trace:
[ 1800.642780] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.642781] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.642784] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.642787] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.642789] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.642791] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.642793] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.642800] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.642804] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.642807] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.642810] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.642813] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.642814] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.642816] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.642817] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.642819] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.642821] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.642822] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.642824] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.642826] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.642829] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.642830] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1801.138678] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1801.138723] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1801.138731] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1801.138738] Preemption disabled at:
[ 1801.138738] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1801.138742] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1801.138743] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1801.138748] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1801.138750] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1801.138752] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1801.138753] Call Trace:
[ 1801.138760] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1801.138762] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1801.138766] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1801.138769] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1801.138772] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1801.138775] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1801.138778] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1801.138785] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1801.138789] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1801.138793] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1801.138796] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1801.138800] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1801.138802] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1801.138804] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1801.138806] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1801.138808] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1801.138810] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1801.138812] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1801.138814] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1801.138817] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1801.138820] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1801.138823] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1801.730659] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1801.730705] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1801.730713] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1801.730721] Preemption disabled at:
[ 1801.730721] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1801.730725] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1801.730726] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1801.730731] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1801.730733] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1801.730735] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1801.730736] Call Trace:
[ 1801.730743] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1801.730746] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1801.730749] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1801.730752] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1801.730755] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1801.730758] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1801.730760] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1801.730768] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1801.730772] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1801.730776] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1801.730779] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1801.730783] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1801.730785] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1801.730787] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1801.730789] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1801.730791] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1801.730793] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1801.730795] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1801.730797] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1801.730800] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1801.730803] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1801.730805] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1801.890632] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1801.890677] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1801.890685] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1801.890693] Preemption disabled at:
[ 1801.890693] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1801.890697] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1801.890698] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1801.890703] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1801.890706] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1801.890708] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1801.890708] Call Trace:
[ 1801.890715] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1801.890718] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1801.890721] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1801.890725] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1801.890727] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1801.890730] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1801.890733] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1801.890741] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1801.890745] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1801.890748] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1801.890751] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1801.890755] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1801.890757] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1801.890759] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1801.890761] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1801.890763] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1801.890765] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1801.890767] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1801.890769] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1801.890772] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1801.890775] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1801.890777] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1803.714543] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1803.714579] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1803.714586] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1803.714593] Preemption disabled at:
[ 1803.714593] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1803.714596] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1803.714597] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1803.714601] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1803.714602] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1803.714603] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1803.714604] Call Trace:
[ 1803.714609] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1803.714611] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1803.714613] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1803.714617] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1803.714618] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1803.714620] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1803.714621] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1803.714628] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1803.714631] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1803.714634] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1803.714637] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1803.714639] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1803.714641] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1803.714642] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1803.714643] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1803.714645] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1803.714646] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1803.714647] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1803.714648] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1803.714650] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1803.714652] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1803.714654] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1803.778526] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1803.778563] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1803.778569] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1803.778576] Preemption disabled at:
[ 1803.778576] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1803.778579] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1803.778580] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1803.778583] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1803.778585] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1803.778587] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1803.778587] Call Trace:
[ 1803.778594] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1803.778596] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1803.778599] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1803.778602] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1803.778604] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1803.778606] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1803.778607] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1803.778615] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1803.778619] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1803.778622] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1803.778624] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1803.778627] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1803.778628] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1803.778630] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1803.778631] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1803.778632] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1803.778634] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1803.778635] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1803.778637] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1803.778639] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1803.778641] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1803.778643] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1746.038020] Call Trace:
[ 1746.038024] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1746.038027] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1746.038030] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1746.038034] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1746.038037] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1746.038039] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1746.038042] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1746.038049] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1746.038052] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1746.038056] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1746.038059] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1746.038062] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1746.038064] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1746.038066] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1746.038068] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1746.038070] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1746.038073] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1746.038074] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1746.038076] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1746.038079] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1746.038082] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1746.038084] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1748.373833] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1748.373871] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1748.373878] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1748.373883] Preemption disabled at:
[ 1748.373883] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1748.373886] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1748.373887] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1748.373891] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1748.373893] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1748.373894] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1748.373895] Call Trace:
[ 1748.373901] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1748.373903] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1748.373906] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1748.373908] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1748.373910] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1748.373912] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1748.373914] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1748.373921] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1748.373924] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1748.373928] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1748.373930] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1748.373933] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1748.373935] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1748.373936] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1748.373938] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1748.373939] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1748.373941] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1748.373942] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1748.373944] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1748.373946] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1748.373948] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1748.373950] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1749.157768] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1749.157813] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1749.157821] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1749.157828] Preemption disabled at:
[ 1749.157828] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1749.157832] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1749.157833] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1749.157838] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1749.157841] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1749.157843] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1749.157843] Call Trace:
[ 1749.157850] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1749.157853] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1749.157857] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1749.157861] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1749.157863] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1749.157866] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1749.157869] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1749.157877] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1749.157880] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1749.157885] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1749.157888] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1749.157891] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1749.157893] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1749.157895] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1749.157897] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1749.157900] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1749.157902] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1749.157904] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1749.157906] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1749.157909] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1749.157912] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1749.157914] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1759.127956] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1759.128001] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1759.128009] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1759.128016] Preemption disabled at:
[ 1759.128016] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1759.128020] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1759.128021] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1759.128026] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1759.128029] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f41
[ 1759.128031] ffff9bf17ece9a00 0000000000000001 ffff9bf178910fc0 ffffbd3641183bd0
[ 1759.128032] Call Trace:
[ 1759.128039] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1759.128041] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1759.128045] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1759.128049] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1759.128052] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1759.128054] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1759.128057] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1759.128066] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1759.128070] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1759.128074] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1759.128078] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1759.128081] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1759.128083] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1759.128085] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1759.128087] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1759.128090] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1759.128092] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1759.128094] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1759.128097] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1759.128100] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1759.128103] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1759.128105] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.036885] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1764.036930] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.036938] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.036945] Preemption disabled at:
[ 1764.036946] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.036950] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.036951] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.036955] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1764.036958] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1764.036960] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1764.036961] Call Trace:
[ 1764.036968] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.036971] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.036975] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.036978] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.036981] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.036983] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.036986] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.037008] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1764.037020] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1764.037031] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1764.037043] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1764.037046] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1764.037049] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.037052] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.037054] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.037056] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.037058] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.037060] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.037062] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.037064] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.037067] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.037070] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.037072] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.372861] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1764.372905] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.372913] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.372920] Preemption disabled at:
[ 1764.372920] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.372924] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.372925] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.372929] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1764.372932] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1764.372934] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1764.372935] Call Trace:
[ 1764.372941] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.372943] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.372947] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.372950] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.372953] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.372955] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.372958] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.372966] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1764.372970] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1764.372974] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1764.372977] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.372980] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.372983] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.372985] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.372986] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.372989] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.372991] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.372993] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.372995] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1764.372998] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.373001] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.373003] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.468854] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1764.468898] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.468906] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.468913] Preemption disabled at:
[ 1764.468913] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.468917] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.468918] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.468923] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1764.468925] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1764.468927] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1764.468928] Call Trace:
[ 1764.468935] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.468937] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.468941] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.468945] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.468947] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.468950] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.468953] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.468960] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1764.468964] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1764.468968] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1764.468971] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.468974] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.468976] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.468979] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.468980] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.468983] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.468985] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.468987] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.468989] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1764.468992] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.468994] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.468996] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.469036] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1764.469064] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.469069] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.469072] Preemption disabled at:
[ 1764.469072] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.469074] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.469075] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.469078] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1764.469081] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 0000000000000000
[ 1764.469084] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1764.469084] Call Trace:
[ 1764.469087] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.469089] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.469092] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.469095] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.469097] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.469100] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.469103] [<ffffffffbcfe6ba0>] ? dma_pool_free+0x20/0xc0
[ 1764.469106] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.469125] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1764.469137] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1764.469148] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1764.469160] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1764.469163] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1764.469165] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.469168] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.469170] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.469172] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.469174] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.469176] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.469178] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.469180] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.469182] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.469185] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.469187] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1765.604790] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1765.604835] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1765.604843] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1765.604850] Preemption disabled at:
[ 1765.604850] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1765.604854] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1765.604855] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1765.604860] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1765.604862] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1765.604864] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1765.604865] Call Trace:
[ 1765.604873] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1765.604875] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1765.604879] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1765.604882] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1765.604885] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1765.604888] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1765.604890] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1765.604914] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1765.604926] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1765.604938] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1765.604950] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1765.604953] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1765.604956] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1765.604960] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1765.604962] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1765.604964] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1765.604966] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1765.604968] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1765.604970] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1765.604972] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1765.604976] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1765.604979] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1765.604981] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1776.212165] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1776.212210] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1776.212218] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1776.212225] Preemption disabled at:
[ 1776.212225] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1776.212229] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1776.212230] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1776.212234] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1776.212237] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1776.212239] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1776.212240] Call Trace:
[ 1776.212246] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1776.212249] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1776.212252] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1776.212256] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1776.212258] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1776.212261] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1776.212264] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1776.212272] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1776.212276] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1776.212280] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1776.212284] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1776.212288] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1776.212290] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1776.212292] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1776.212294] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1776.212296] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1776.212298] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1776.212300] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1776.212302] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1776.212305] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1776.212308] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1776.212310] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1779.827945] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1779.827990] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1779.827998] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1779.828005] Preemption disabled at:
[ 1779.828005] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1779.828009] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1779.828010] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1779.828015] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1779.828017] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1779.828020] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1779.828020] Call Trace:
[ 1779.828027] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1779.828030] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1779.828033] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1779.828037] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1779.828039] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1779.828042] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1779.828045] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1779.828054] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1779.828057] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1779.828061] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1779.828064] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1779.828068] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1779.828070] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1779.828072] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1779.828074] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1779.828076] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1779.828078] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1779.828080] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1779.828082] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1779.828085] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1779.828088] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1779.828090] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1781.139876] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1781.139921] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1781.139929] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1781.139937] Preemption disabled at:
[ 1781.139937] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1781.139941] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1781.139942] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1781.139947] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133c00
[ 1781.139950] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1781.139952] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c40
[ 1781.139953] Call Trace:
[ 1781.139960] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1781.139963] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1781.139967] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1781.139971] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1781.139973] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1781.139976] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1781.139979] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1781.140004] [<ffffffffc043aec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[ 1781.140015] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1781.140027] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1781.140031] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1781.140033] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1781.140037] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1781.140039] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1781.140041] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1781.140043] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1781.140045] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1781.140048] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1781.140050] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1781.140053] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1781.140056] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1781.140058] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1781.315860] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1781.315902] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1781.315910] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1781.315917] Preemption disabled at:
[ 1781.315917] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1781.315921] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1781.315921] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1781.315926] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1781.315928] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1781.315931] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1781.315931] Call Trace:
[ 1781.315938] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1781.315941] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1781.315945] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1781.315948] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1781.315951] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1781.315954] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1781.315957] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1781.315965] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1781.315968] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1781.315972] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1781.315975] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1781.315979] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1781.315981] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1781.315983] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1781.315985] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1781.315987] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1781.315989] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1781.315991] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1781.315993] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1781.315996] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1781.315999] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1781.316001] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.011770] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.011817] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.011826] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.011833] Preemption disabled at:
[ 1783.011833] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.011837] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.011838] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.011843] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.011845] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.011848] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.011848] Call Trace:
[ 1783.011855] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.011858] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.011862] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.011865] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.011868] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.011871] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.011874] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.011882] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.011887] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.011891] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.011895] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.011899] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.011902] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.011904] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.011907] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.011909] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.011912] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.011914] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.011916] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.011919] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.011922] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.011924] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.107759] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.107796] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.107803] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.107809] Preemption disabled at:
[ 1783.107809] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.107812] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.107813] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.107816] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.107818] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.107820] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.107821] Call Trace:
[ 1783.107826] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.107828] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.107831] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.107834] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.107836] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.107838] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.107840] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.107846] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.107849] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.107852] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.107855] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.107857] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.107859] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.107860] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.107862] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.107863] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.107865] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.107866] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.107868] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.107870] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.107872] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.107874] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.219742] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.219780] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.219786] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.219792] Preemption disabled at:
[ 1783.219792] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.219796] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.219796] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.219800] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.219802] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.219804] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.219804] Call Trace:
[ 1783.219810] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.219812] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.219815] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.219818] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.219820] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.219822] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.219824] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.219830] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.219833] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.219836] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.219839] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.219841] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.219842] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.219844] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.219845] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.219847] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.219849] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.219850] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.219851] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.219854] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.219856] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.219858] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.507721] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.507765] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.507773] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.507781] Preemption disabled at:
[ 1783.507781] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.507785] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.507786] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.507791] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.507793] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.507795] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.507796] Call Trace:
[ 1783.507803] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.507805] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.507809] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.507812] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.507815] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.507817] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.507820] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.507829] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.507832] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.507836] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.507839] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.507843] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.507845] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.507847] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.507849] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.507852] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.507854] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.507856] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.507858] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.507861] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.507864] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.507866] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.747731] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.747779] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.747787] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.747795] Preemption disabled at:
[ 1783.747795] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.747799] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.747800] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.747804] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.747808] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.747810] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.747810] Call Trace:
[ 1783.747818] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.747820] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.747824] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.747828] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.747831] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.747833] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.747836] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.747845] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.747848] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.747853] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.747856] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.747859] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.747862] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.747864] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.747865] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.747868] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.747870] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.747872] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.747874] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.747877] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.747880] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.747883] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.843720] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.843759] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.843766] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.843772] Preemption disabled at:
[ 1783.843772] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.843775] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.843776] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.843779] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.843781] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.843783] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.843783] Call Trace:
[ 1783.843790] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.843792] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.843795] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.843798] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.843799] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.843801] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.843803] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.843810] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.843813] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.843816] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.843819] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.843821] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.843822] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.843824] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.843825] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.843826] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.843828] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.843829] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.843830] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.843832] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.843834] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.843836] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.891708] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.891744] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.891750] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.891756] Preemption disabled at:
[ 1783.891756] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.891758] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.891759] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.891762] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.891764] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.891765] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.891765] Call Trace:
[ 1783.891771] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.891773] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.891775] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.891778] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.891779] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.891781] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.891782] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.891788] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.891791] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.891794] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.891797] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.891799] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.891800] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.891802] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.891803] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.891804] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.891805] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.891806] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.891807] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.891809] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.891811] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.891812] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.923705] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.923741] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.923747] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.923753] Preemption disabled at:
[ 1783.923753] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.923756] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.923757] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.923760] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.923761] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.923763] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.923763] Call Trace:
[ 1783.923769] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.923770] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.923773] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.923776] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.923777] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.923779] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.923780] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.923786] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.923789] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.923791] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.923794] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.923796] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.923798] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.923799] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.923800] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.923801] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.923802] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.923804] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.923805] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.923807] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.923809] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.923810] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.987703] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.987743] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.987749] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.987755] Preemption disabled at:
[ 1783.987756] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.987759] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.987760] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.987763] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.987765] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.987767] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.987767] Call Trace:
[ 1783.987773] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.987775] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.987778] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.987780] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.987782] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.987784] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.987785] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.987792] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.987795] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.987799] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.987802] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.987804] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.987806] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.987807] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.987809] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.987810] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.987812] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.987813] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.987814] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.987817] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.987819] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.987820] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1785.875585] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1785.875630] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1785.875637] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1785.875644] Preemption disabled at:
[ 1785.875645] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1785.875649] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1785.875650] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1785.875655] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1785.875657] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1785.875660] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1785.875661] Call Trace:
[ 1785.875667] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1785.875669] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1785.875673] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1785.875677] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1785.875679] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1785.875682] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1785.875685] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1785.875706] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1785.875717] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1785.875729] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1785.875741] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1785.875744] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1785.875747] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1785.875750] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1785.875753] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1785.875755] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1785.875757] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1785.875759] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1785.875761] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1785.875763] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1785.875767] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1785.875769] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1785.875772] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1786.851550] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1786.851596] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1786.851604] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1786.851611] Preemption disabled at:
[ 1786.851611] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1786.851615] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1786.851616] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1786.851621] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1786.851624] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1786.851626] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1786.851627] Call Trace:
[ 1786.851634] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1786.851637] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1786.851640] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1786.851644] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1786.851647] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1786.851650] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1786.851653] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1786.851661] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1786.851665] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1786.851670] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1786.851673] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1786.851677] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1786.851679] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1786.851681] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1786.851683] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1786.851685] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1786.851688] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1786.851690] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1786.851692] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1786.851696] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1786.851699] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1786.851702] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1793.555146] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1793.555192] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1793.555200] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1793.555209] Preemption disabled at:
[ 1793.555209] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1793.555213] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1793.555215] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1793.555220] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1793.555224] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1793.555226] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1793.555227] Call Trace:
[ 1793.555236] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1793.555238] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1793.555243] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1793.555247] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1793.555250] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1793.555253] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1793.555256] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1793.555265] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1793.555270] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1793.555274] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1793.555278] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1793.555281] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1793.555283] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1793.555285] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1793.555287] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1793.555290] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1793.555292] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1793.555294] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1793.555296] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1793.555299] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1793.555302] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1793.555304] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1795.283023] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1795.283070] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1795.283079] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1795.283086] Preemption disabled at:
[ 1795.283086] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1795.283090] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1795.283091] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1795.283096] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133c00
[ 1795.283098] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1795.283100] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c40
[ 1795.283101] Call Trace:
[ 1795.283108] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1795.283111] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1795.283115] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1795.283119] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1795.283121] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1795.283124] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1795.283127] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1795.283150] [<ffffffffc043aec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[ 1795.283162] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1795.283174] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1795.283177] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1795.283179] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1795.283183] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1795.283185] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1795.283187] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1795.283189] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1795.283191] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1795.283193] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1795.283195] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1795.283198] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1795.283201] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1795.283203] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1797.682890] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1797.682941] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1797.682950] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1797.682956] Preemption disabled at:
[ 1797.682956] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1797.682960] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1797.682960] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1797.682965] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1797.682966] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1797.682968] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1797.682969] Call Trace:
[ 1797.682977] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1797.682978] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1797.682983] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1797.682986] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1797.682988] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1797.682990] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1797.682992] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1797.683002] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1797.683006] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1797.683010] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1797.683013] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1797.683017] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1797.683019] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1797.683021] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1797.683022] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1797.683024] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1797.683025] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1797.683027] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1797.683028] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1797.683033] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1797.683035] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1797.683037] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1797.970865] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1797.970910] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1797.970918] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1797.970925] Preemption disabled at:
[ 1797.970925] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1797.970929] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1797.970930] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1797.970934] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1797.970937] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1797.970939] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1797.970940] Call Trace:
[ 1797.970947] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1797.970950] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1797.970953] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1797.970957] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1797.970959] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1797.970962] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1797.970964] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1797.970973] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1797.970976] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1797.970981] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1797.970984] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1797.970987] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1797.970989] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1797.970991] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1797.970993] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1797.970995] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1797.970997] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1797.970999] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1797.971001] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1797.971004] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1797.971007] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1797.971009] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.810770] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.810816] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.810824] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.810832] Preemption disabled at:
[ 1799.810832] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.810837] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.810838] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.810842] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.810845] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.810847] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.810848] Call Trace:
[ 1799.810855] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.810857] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.810861] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.810864] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.810867] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.810869] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.810872] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.810881] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.810885] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.810889] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.810893] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.810896] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.810898] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.810900] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.810902] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.810904] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.810906] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.810908] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.810910] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.810913] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.810916] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.810918] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.874762] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.874799] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.874804] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.874810] Preemption disabled at:
[ 1799.874810] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.874813] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.874813] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.874817] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.874818] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.874820] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.874820] Call Trace:
[ 1799.874826] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.874827] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.874830] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.874833] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.874834] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.874836] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.874837] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.874844] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.874846] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.874849] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.874852] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.874854] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.874856] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.874857] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.874858] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.874859] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.874860] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.874862] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.874863] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.874865] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.874867] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.874869] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.954748] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.954780] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.954786] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.954792] Preemption disabled at:
[ 1799.954792] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.954795] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.954795] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.954798] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.954800] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.954801] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.954801] Call Trace:
[ 1799.954806] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.954808] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.954810] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.954812] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.954814] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.954815] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.954817] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.954822] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.954825] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.954828] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.954830] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.954832] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.954833] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.954834] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.954835] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.954836] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.954838] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.954839] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.954840] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.954842] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.954843] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.954845] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.970756] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.970791] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.970798] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.970803] Preemption disabled at:
[ 1799.970804] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.970807] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.970807] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.970811] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.970813] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.970814] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.970815] Call Trace:
[ 1799.970821] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.970822] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.970825] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.970828] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.970829] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.970831] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.970833] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.970840] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.970843] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.970846] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.970849] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.970851] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.970853] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.970854] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.970856] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.970857] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.970858] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.970860] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.970861] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.970863] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.970865] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.970867] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.034753] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.034794] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.034802] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.034808] Preemption disabled at:
[ 1800.034808] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.034812] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.034812] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.034816] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.034818] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.034820] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.034820] Call Trace:
[ 1800.034826] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.034828] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.034831] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.034834] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.034836] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.034838] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.034841] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.034848] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.034852] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.034856] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.034859] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.034862] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.034863] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.034865] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.034867] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.034868] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.034870] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.034872] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.034874] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.034877] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.034879] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.034881] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.242729] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.242774] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.242782] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.242789] Preemption disabled at:
[ 1800.242789] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.242794] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.242794] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.242799] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.242802] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.242804] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.242805] Call Trace:
[ 1800.242812] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.242814] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.242818] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.242822] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.242825] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.242827] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.242830] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.242839] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.242842] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.242846] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.242850] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.242853] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.242855] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.242858] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.242860] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.242862] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.242864] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.242866] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.242868] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.242871] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.242874] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.242876] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.594722] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.594770] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.594778] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.594785] Preemption disabled at:
[ 1800.594785] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.594789] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.594790] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.594796] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.594799] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.594801] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.594802] Call Trace:
[ 1800.594809] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.594812] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.594816] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.594819] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.594823] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.594826] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.594829] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.594838] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.594842] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.594847] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.594850] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.594855] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.594857] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.594859] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.594862] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.594864] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.594866] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.594868] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.594871] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.594874] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.594877] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.594879] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.626721] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.626769] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.626777] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.626785] Preemption disabled at:
[ 1800.626785] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.626789] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.626790] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.626795] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.626798] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.626800] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.626801] Call Trace:
[ 1800.626809] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.626811] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.626815] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.626818] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.626821] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.626824] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.626827] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.626836] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.626840] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.626844] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.626848] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.626852] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.626855] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.626857] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.626859] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.626861] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.626864] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.626866] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.626868] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.626872] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.626875] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.626877] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.642707] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.642747] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.642754] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.642761] Preemption disabled at:
[ 1800.642761] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.642764] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.642765] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.642769] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.642771] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.642773] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.642774] Call Trace:
[ 1800.642780] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.642781] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.642784] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.642787] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.642789] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.642791] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.642793] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.642800] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.642804] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.642807] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.642810] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.642813] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.642814] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.642816] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.642817] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.642819] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.642821] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.642822] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.642824] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.642826] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.642829] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.642830] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1801.138678] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1801.138723] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1801.138731] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1801.138738] Preemption disabled at:
[ 1801.138738] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1801.138742] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1801.138743] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1801.138748] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1801.138750] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1801.138752] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1801.138753] Call Trace:
[ 1801.138760] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1801.138762] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1801.138766] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1801.138769] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1801.138772] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1801.138775] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1801.138778] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1801.138785] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1801.138789] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1801.138793] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1801.138796] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1801.138800] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1801.138802] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1801.138804] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1801.138806] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1801.138808] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1801.138810] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1801.138812] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1801.138814] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1801.138817] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1801.138820] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1801.138823] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1801.730659] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1801.730705] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1801.730713] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1801.730721] Preemption disabled at:
[ 1801.730721] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1801.730725] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1801.730726] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1801.730731] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1801.730733] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1801.730735] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1801.730736] Call Trace:
[ 1801.730743] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1801.730746] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1801.730749] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1801.730752] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1801.730755] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1801.730758] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1801.730760] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1801.730768] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1801.730772] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1801.730776] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1801.730779] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1801.730783] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1801.730785] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1801.730787] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1801.730789] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1801.730791] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1801.730793] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1801.730795] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1801.730797] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1801.730800] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1801.730803] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1801.730805] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1801.890632] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1801.890677] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1801.890685] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1801.890693] Preemption disabled at:
[ 1801.890693] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1801.890697] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1801.890698] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1801.890703] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1801.890706] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1801.890708] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1801.890708] Call Trace:
[ 1801.890715] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1801.890718] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1801.890721] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1801.890725] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1801.890727] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1801.890730] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1801.890733] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1801.890741] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1801.890745] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1801.890748] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1801.890751] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1801.890755] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1801.890757] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1801.890759] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1801.890761] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1801.890763] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1801.890765] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1801.890767] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1801.890769] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1801.890772] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1801.890775] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1801.890777] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1803.714543] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1803.714579] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1803.714586] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1803.714593] Preemption disabled at:
[ 1803.714593] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1803.714596] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1803.714597] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1803.714601] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1803.714602] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1803.714603] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1803.714604] Call Trace:
[ 1803.714609] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1803.714611] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1803.714613] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1803.714617] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1803.714618] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1803.714620] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1803.714621] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1803.714628] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1803.714631] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1803.714634] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1803.714637] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1803.714639] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1803.714641] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1803.714642] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1803.714643] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1803.714645] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1803.714646] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1803.714647] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1803.714648] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1803.714650] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1803.714652] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1803.714654] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1803.778526] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1803.778563] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1803.778569] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1803.778576] Preemption disabled at:
[ 1803.778576] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1803.778579] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1803.778580] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1803.778583] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1803.778585] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1803.778587] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1803.778587] Call Trace:
[ 1803.778594] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1803.778596] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1803.778599] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1803.778602] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1803.778604] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1803.778606] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1803.778607] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1803.778615] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1803.778619] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1803.778622] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1803.778624] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1803.778627] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1803.778628] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1803.778630] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1803.778631] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1803.778632] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1803.778634] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1803.778635] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1803.778637] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1803.778639] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1803.778641] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1803.778643] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
Last edit: 15 May 2018 23:40 by andypugh.
13 May 2018 05:17 #110647
Replied by cmorley on topic odd error message popping up for missing GST file?
The problem is not apparent to me.
Does a sim config load up properly - maybe try AXIS?
Chris M
Chris M
The following user(s) said Thank You: Lcvette
13 May 2018 05:30 #110649
by Lcvette
Replied by Lcvette on topic odd error message popping up for missing GST file?
i have a basic config i made using pncconfig without all the atc and python stuff and it loads and runs perfect using axis, i had not thought of trying axis on this one, i will do that now! good idea! will report back!
Time to create page: 0.301 seconds
