7i76e with 7i85S to control 9 steppers
06 Nov 2018 00:04 #120060
Replied by cmorley on topic 7i76e with 7i85S to control 9 steppers
You don't need power or even the card for pncconf.
You do need field power supplied for some of the pins to show up in HAL when running linuxcnc.
Look like pncconf is mis-naming the 7i76e pins.
I suggest manually renaming them in the HAL file.
Chris m
Chris m
06 Nov 2018 00:10 - 06 Nov 2018 00:12 #120061
Replied by PCW on topic 7i76e with 7i85S to control 9 steppers
pncconf will create the correct connections and pin names but you must select them from the "7I76 I/O" tab
pncconf doesnt need the card connected unless you run one of the tests
Not sure why your field I/O is not there, maybe your GPIO settings are causing an issue
(in general you should not mess with GPIO at all on a 7I76E unless you are manipulating one of the expansion connectors I/O bits)
Last edit: 06 Nov 2018 00:12 by PCW.
06 Nov 2018 01:40 #120067
by cogzoid
Replied by cogzoid on topic 7i76e with 7i85S to control 9 steppers
Ah, I didn't realize that the 7i76 I/O tab needed to be populated like that. It felt like I was double entering things, so I didn't fill it out. Now the .hal file is reading the correct "input-16", etc...
Sorry for having to ask these simple questions, but I'm slowly climbing up this learning curve.
06 Nov 2018 23:47 #120128
by cogzoid
Fresh off of the PncConf, the Digital Outputs don't work for me.
When I try to run linuxcnc I get this error code:If I comment out the digital outs, it also fails at the homing inputs.
I've attached the .ini and .hal files. I am absolutely perplexed that people are able to get this up and running on the first try.
./DumbTest.hal:43: Pin 'hm2_7i76e.0.7i76.0.0.output-08' does not exist
06 Nov 2018 23:59 #120131
by cogzoid
I decided to try a multi-prong approach to the homing:
linuxcnc only fails on the input-00 and not on the gpio.015.in lines. What am I doing wrong?
# external input signals
# --- HOME-Y ---
net home-y <= hm2_7i76e.0.gpio.015.in
# --- HOME-Z ---
net home-z <= hm2_7i76e.0.gpio.016.in
# --- HOME-X ---
net home-x <= hm2_7i76e.0.7i76.0.0.input-00
07 Nov 2018 04:09 #120143
First I would delete any gpio related lines in the hal file since they are not appropriate
for your use
if the field I/O pins (hm2_7i76e.0.7i76.0.0.xxxxx) are not found that means there an issue with the field I/O
For field I/O to work you need:
8 to 24VDC on TB1 (+8 to 24 on pin 1 = bottom Gnd on pin 8)
This must be present on linuxCNC startup
W1 left
W8 left
for your use
W1 left
W8 left
07 Nov 2018 17:53 #120189
by cogzoid
My field power pins were correct. However, I checked the jumper pins as you suggested and noticed that W8 was to the right, in "SETUP" mode. The 7i76e manual explains that it changes the baud rate of the communication, but it doesn't explain any other difference between SETUP or OPERATE mode. I had no idea that it would deactivate the homing pins. I figured I was still trying to get things set up, so I should be in SETUP mode.
07 Nov 2018 17:58 #120190
Actually the manual does state:
"W8 must be in the "operate" mode for normal operation."
07 Nov 2018 19:04 #120192
by cogzoid
I just wish it explained the difference between "normal operation" and "setup" a little more clearly. I feel like with just a few test pieces and a jumble of wires laid out on my desk I'm far from "normal operation."
Anyway, thanks for all of your help. I've got the first homing switch working (still gonna test all 8). My next test will be to control the digital outs with M62/M63 commands.
Soon we're going to tackle the problem of running linuxcnc over the network. If we can lick that problem then we'll be ready to update the robot to the new system. I'm definitely looking forward to that!
08 Nov 2018 12:16 #120251
Maybe the Mesa manuals should call "Setup" "Card Firmware Flashing Mode" instead?
Replied by andypugh on topic 7i76e with 7i85S to control 9 steppers
Time to create page: 0.232 seconds
