7i76e with two ethernet ports
16 Jun 2018 14:05 #112475
by trilobyte
7i76e with two ethernet ports was created by trilobyte
id like to set up an Up Squared with two ethernet ports and a 7i76e.
how can i get an network connection with dhcp for the internet connection and on the other port the connection to the 7i76e?
BR
peter
BR
peter
16 Jun 2018 15:27 #112480
Replied by PCW on topic 7i76e with two ethernet ports
I think many 7I76E users will have two network connections basically you need to know the device names of the two Ethernet interfaces and set them up appropriately
Plugging in a active Ethernet cable and running the
ip a
command at a terminal will allow you to identify which port is which
Then you need to set one up for normal DHCP (this is likely the default setup)
and the other (7I76E connection) with the desired static IP as described in the hm2_eth manual page
ip a
17 Jun 2018 17:37 #112513
by trilobyte
Replied by trilobyte on topic 7i76e with two ethernet ports
ip a helped, tnx!
the machine made first movements:
www.trilobyte.ch/pix/gal/werkstatt/schau.../20180617_165700.mp4
br
Peter
br
Peter
Time to create page: 0.135 seconds
