Problem matching velocitys
18 Jul 2018 17:28 #114483
by casetero
Replied by casetero on topic Problem matching velocitys
I will try it tomorrow.
But if i would set that bad, it wouldnt match the distances too? Or as it is working in velocity mode the distances dont matter?
I say this because my original configuration was with no encoders ( no feedback of position) and it worked in position mode, and it worked well. Maybe i changed anything in the drivers and i dont remember. Tomorrow i will try it and see what happens.
Thank you PCW. Sorry for my english.
19 Jul 2018 03:03 #114513
Replied by PCW on topic Problem matching velocitys
With a closed loop system, you can set the stepgen scale to almost anything and "tune around it" since the PID loop will force the encoder count to be correct, but it will make the stepgen velocity settings behave as strangely, as you noticed...
19 Jul 2018 12:45 #114527
by casetero
Ok, that was exactly the problem. Now it works correctly.
Thank you very much PCW. By the way, i´m the spanish that called you by phone one or two months ago!
23 Jul 2018 09:50 #114693
Replied by andypugh on topic Problem matching velocitys
I can't remember what effect it has, but I see your [TRAJ] MAX_VELOCITY is lower than each axis max.
Time to create page: 0.135 seconds
