7i76e not stepping
17 Jul 2018 08:53 #114356
by mngr0
7i76e not stepping was created by mngr0
Hi everybody!
I have recently bought a 7i76E, and I am trying to move a stepper with it.
I connected successfully the board to the computer with linuxcnc with an ethernet cable,
Used PnCConf to create an ini and hal file, and then started axis.
I tryed to manually move X, but no step came out from the 7i76E.
as I am using a stepper driver with ground in common with the 7i76E, I used the STEP+ pin, is this right?
then there is the thing with mesaflash thing that I have not understood well... I think I should use it to load something on the 7i76e, but I am not sure of what and how... (I loaded nothing at all, still default config)
Can, you please help me?
17 Jul 2018 11:25 #114361
Replied by cmorley on topic 7i76e not stepping
You shouldn't need mesaflash.
The fact the config loaded without error is a good start.
Does the display show movement?
Chris M
Chris M
17 Jul 2018 11:40 #114362
by mngr0
Replied by mngr0 on topic 7i76e not stepping
yes, the tool moves in the display.
I connected the stepper to the first instance of the 7i76E (pin 1-6 of TB2)
and in the hal file X is connected to the hm2_eth.0
I have also tryed to connect the stepper to the other isntances on TB2 (later I will try the ones on TB3 too)
17 Jul 2018 11:43 #114363
Replied by rodw on topic 7i76e not stepping
You might find the connection sheet here helpful
forum.linuxcnc.org/27-driver-boards/3191...n-sheet?limitstart=0
17 Jul 2018 11:54 #114364
by mngr0
thanks rodw, I already have connected the stepper driver according to that manual.
It' s very useful I must say!
now It's connected to STEPPER 0. I tried to read STEP+ with an analyzer and it does not go up and down as it should
17 Jul 2018 11:58 #114365
Replied by PCW on topic 7i76e not stepping
What are your step pulse length settings? A good place to start is to set these to double the minimum drive specifications.
(people often set these at the drives minimum settings which have a good chance of not working)
17 Jul 2018 12:09 #114369
This may or may not be useful as I use the development branch (v 2.8) which is different to the stable 2.7 release in how joints and axes are configured, but I did publish a minimalist config for a 7i76e here
forum.linuxcnc.org/47-hal-examples/34072...ranch-gantry-example
There are a number of things you could have wrong in your ini file. I know when I got mine going first, I had very slow speeds so the steppers barely moved. Also some of the steplen parameters might be wrong for your hardware.....as PCW has suggested.
I would open up halshow (Show Machine Configuration menu) and browse the tree to see if pins for the 7i76e are showing. If it is, its just a configuration error....
17 Jul 2018 13:35 #114388
by mngr0
thank you guys!
I played a little with steplen and step_space and the motor starded moving! it still needs some tweaking, but I can work on it!
thank you again!
thank you again!
Time to create page: 0.095 seconds
