- Configuring LinuxCNC
- PnCConf Wizard
- Error „pin „halui.spindle.forward“ does not exist“ with PnCConf and LinuxCNC 2.8
06 Oct 2018 10:37 #118490
by decor82
Error „pin „halui.spindle.forward“ does not exist“ with PnCConf and LinuxCNC 2.8 was created by decor82
Hallo,
i am really new to LinuxCNC and get a error when I try to start LinuxCNC with a config from PnCConf.
I am using a Mesa 7I76e Card and while I build the config with PnCConf I can move all 3 axis. But after I complete the wizard, I get the error, „pin „halui.spindle.forward“ does not exist“.
The LinuxCNC version is 2.8 from the buildbot repository.
I read something about halui.spindle.N.forward but I am not experienced enough to know what to do now.
Hope someone can point me to the right direction.
Best regards,
Jan
Best regards,
Jan
06 Oct 2018 21:22 #118499
Replied by cmorley on topic Error „pin „halui.spindle.forward“ does not exist“ with PnCConf and LinuxCNC 2.8
There was some work pushed into master lately regarding spindles.
I would bet this is the cause of your error.
I'll do some looking.
Chris M
Chris M
06 Oct 2018 21:30 #118501
Yes you are right.
anywhere you find something like:
change it to:
halui.spindle.0.forward
Hopefully this will be fixed in Master soon.
Chris M
change it to:
Chris M
06 Oct 2018 22:18 #118506
We have pushed a fix into master for this problem.
Please update your linuxcnc version. (or manually fix the names as shown before)
Chris M
Chris M
07 Oct 2018 10:07 #118511
by decor82
Replied by decor82 on topic Error „pin „halui.spindle.forward“ does not exist“ with PnCConf and LinuxCNC 2.8
Thanks for the advice.
Changed halui.spindle.forward to halui.spindle.0.forward and all the other halui.spindle pins and the problem is solved.
- PnCConf Wizard
Time to create page: 0.071 seconds
