- Configuring LinuxCNC
- PnCConf Wizard
- pncconf - 5i25 - any way of making unused encoder inputs into GPIO's?
17 Oct 2018 21:50 #118961
by Dr. John
I'm using a 5i25 with the 5i25_prob_rfx2 "firmware". I'm also using a cheap "standard" breakout. This means that pins 10, 11, 12, 13 and 15 are inputs only while pins 14, 16 and 17 are outputs only. (This has nothing to do with the 5i25 per se. It's a limit of the breakout card.) I'd like to use pins 11, 12 and 13 for limit/home inputs. However, it seems that this is impossible to do with pncconf. Although it shows that there is an unused encoder, that seems to be mapped to pins 11, 12 and 13, it seems impossible to use these pins as GPIO pins, much less configure them to be used as limit inputs.
Any thoughts? Help is much appreciated.
18 Oct 2018 12:01 #118989
Replied by andypugh on topic pncconf - 5i25 - any way of making unused encoder inputs into GPIO's?
If you configure to have zero encoders then the encoder pins should be freed up for GPIO.
I am not sure how to do that in PnCConf, but the result you want in the HAL file would be something like
You can even change inputs to outputs and vice-versa on the 5i25, but the BoB is unlikely to be bidirectional.
loadrt hm2_pci config=".... num_encoders=0 ...."
18 Oct 2018 12:49 #118993
Replied by PCW on topic pncconf - 5i25 - any way of making unused encoder inputs into GPIO's?
Encoder inputs are available as GPIO inputs without doing anything special (like disabling the encoders), though pncconf may not give you the option to use these inputs
You need to disable the encoder(s) if you wish to use the corresponding GPIO pins as _outputs_
18 Oct 2018 13:35 #118995
Replied by cmorley on topic pncconf - 5i25 - any way of making unused encoder inputs into GPIO's?
In pncconf on the mesa page look at the configuration tab.
There is a line about number of encoders - change this line then press the 'accept component changes' button.
Now the encoder will be replaced with GPIO on the connector tabs.
Chris M
Chris M
18 Oct 2018 17:45 #119006
by Dr. John
Replied by Dr. John on topic pncconf - 5i25 - any way of making unused encoder inputs into GPIO's?
Thanks Chris! That's what I needed. Now on to the next hurdle!
- PnCConf Wizard
Time to create page: 0.123 seconds
