Force acis to maximise and homing sequence
03 Jan 2019 07:52 #123392
by trilobyte
Force acis to maximise and homing sequence was created by trilobyte
i am setting up a lathe with a 7I76e. i checked the checkbox "force axis to maximise (or something like that)
but this isn't working and if i load the setting again in pncconf the checkbox is unchecked.
then there is another problem. if i set the homeing sequence x axis 1 and z axis 2. this results in 0 and -1 in the ini file?
are these known problems?
Peter
Peter
03 Jan 2019 09:03 #123393
Replied by cmorley on topic Force acis to maximise and homing sequence
What version of linuxcnc are you using?
In 2.7 it seemed to work for me.
Other then depending on the window manager AXIS is displayed minimized by default - something that I am not sure pncconf can do anything about.
also I did have to mess with the code to set AXIS to maximum.
How did you set the home sequence?
Chris M
Chris M
03 Jan 2019 10:15 - 03 Jan 2019 10:29 #123401
by trilobyte
Replied by trilobyte on topic Force acis to maximise and homing sequence
i installed the r13 debian stretch image and i'm working with the actual master release.
i have set the homeing sequence in pncconf. i tryed different things. X set to 1, Z set to 2 and at another try i set x to 0 and Z to 1.
both results in an -1 in the ini file
Peter
Peter
Last edit: 03 Jan 2019 10:29 by trilobyte.
03 Jan 2019 10:24 - 03 Jan 2019 10:27 #123402
by trilobyte
My pnccconf file and the resulting hal and ini:
schaublin125.pncconf
schaublin125.hal
schaublin125.ini
btw: i found a (cosmetic) bug in the settings for the digital outputs. they are names as Digital out 0,1,2,1 instead of 0,1,2,3
peter
schaublin125.hal
schaublin125.ini
peter
Last edit: 03 Jan 2019 10:27 by trilobyte.
03 Jan 2019 11:40 #123404
ok I pushed a fix for these to master.
Chris M
Chris M
The following user(s) said Thank You: trilobyte
03 Jan 2019 19:32 #123422
by trilobyte
after an apt-get update, apt-get dist-upgrade i openend the config again, now it is working as expected!
tnx!
peter
tnx!
peter
04 Jan 2019 00:24 #123442
Excellent - thanks for the report.
If you want true fullscreen you can uncomment a line in the .axisrc in your home folder.
Chris M
Chris M
