Comments on settings
- yoshimitsuspeed
30 Jan 2019 20:33 #125335
by yoshimitsuspeed
Comments on settings was created by yoshimitsuspeed
When I went to set up pnconf it set output scale to -10000. Maybe there was something I missed but I have gone through many times and can't find an input where I might have manually made it do it. Maybe it's something I did but if it's a bug I thought I would mention it.
It would also be really nice if the max RPM in the wizard was increased. For example a lot of spindles go to 24k.
31 Jan 2019 14:48 #125388
by pl7i92
Replied by pl7i92 on topic Comments on settings
The wizards are for a Basic Setup
You might go to all the stuff afterwards and set it to your Needs
Standard servo Mashines are only at 8k RPM
31 Jan 2019 23:45 #125438
Replied by cmorley on topic Comments on settings
Can you post your pncconf file so I can diagnosis the problem?
Yes I can raise the spindle max rpm
What version of linuxcnc are you using?
Chris M
Chris M
