Mesa 5i25+7i85S+7i66
07 Feb 2019 12:38 #125918
by lsv80
Mesa 5i25+7i85S+7i66 was created by lsv80
Hi!
Who has an config file for Mesa 5i25+7i85S+7i66?
08 Feb 2019 08:06 #125980
by pl7i92
Replied by pl7i92 on topic Mesa 5i25+7i85S+7i66
Hi
7i66-8
or 7i66-24
7i66-8
or 7i66-24
08 Feb 2019 08:26 #125982
by lsv80
Replied by lsv80 on topic Mesa 5i25+7i85S+7i66
7i66-8
08 Feb 2019 08:35 #125983
by lsv80
Who knows what the red CR34 indicator on the 7i66-8 board means?
08 Feb 2019 14:46 #126002
Replied by PCW on topic Mesa 5i25+7i85S+7i66
It means "fault"
Its expected to be illuminated at power up before host communication is established
since you will always have at least one fault (communication watchdog timeout)
08 Feb 2019 15:16 - 08 Feb 2019 15:22 #126003
by lsv80
Error because the wires are not properly connected or because there is no config file?
Last edit: 08 Feb 2019 15:22 by lsv80.
08 Feb 2019 15:26 #126004
Both, you need at least:
1. A proper connection between the 7I66 and the 7I85S
2. Correct firmware on the 5I25 (5I25_7i85sx2.bit)
3. LinuxCNC (or at least the driver and read/write thread) running
Before the red light will go out (and the green light will blink)
08 Feb 2019 15:47 #126005
by lsv80
08 Feb 2019 16:49 #126010
Yes pncconf has no direct support for the 7I66 but you can make a generic 7i85sx2 configuration
and add the 7I66 I/O to the hal file
If you make a generic 7I85sx2 configuration and start it, you can list all the 7I66 pins with:
and then use the 7i66pins.txt file as a "donor" file for copy pasting into the hal file and
connecting them to the desired LinuxCNC pins/signals.
halcmd show pin | grep 7i66 >7i66pins.txt
08 Feb 2019 17:51 #126012
by lsv80
I so and wanted to do as you wrote, but I cannot see this board 7i66.
I can't turn off this red light on 7i66. (
Do I need to install the driver "sserial" for 7i66 or is it already preinstalled?
I tried to install this driver, but my command fails "sudo ./updatess 7i66 5i25 2".
Time to create page: 0.142 seconds
