Mesa 7I76E + HSS60 Driver parameters ------ losing stepps
- MarcoGaspar
11 Feb 2019 17:26 - 11 Feb 2019 23:11 #126207
by MarcoGaspar
Hello,
Does any one can tell me the parameters for Nema24 3N.m Closed Loop Stepper Servo Motor 88mm + HSS60
I change my old stepper motors and drivers to Nema24 3N.m Closed Loop Stepper Servo Motor 88mm + HSS60 and now when i move forward and backward any value below 0.05 the machine axis starts to increment almost 0.01 at each step forward and backward.
I try all the resolution of the stepper driver without luck.
OLD ____> New
2005 Ballscrew _____> 2010 Ballscrew
425 oz stepper _____> Nema24 3N.m Closed Loop Stepper Servo Motor 88mm
Driver DM860a _____> Driver HSS60
Best Regards,
Marco Gaspar
OLD ____> New
Best Regards,
Marco Gaspar
Last edit: 11 Feb 2019 23:11 by MarcoGaspar.
12 Feb 2019 07:53 #126251
by pl7i92
Replied by pl7i92 on topic Mesa 7I76E + HSS60 Driver parameters ------ losing stepps
The HSS60
require a 2500ns step rate
you shoudt setup for
2500
2500
8000
12000
and give your mashine a best off timingbelt system for 2005 it is 20/25 Teeth so 1,25
for the 2010 it is 2.5 to get 0,01 accuracy at max speed
but you may look for a better one so stay with 20/25 at 400steps halfstepping for best speed and 0,005mm acuracy per step
As lower the microstepping as better the mashine performence
as special on NOT Direct Motor Drive SAYing timingbelt Smooth start
I got a mashine running 12m/min at this drivers 2Nm Stepepr Hybrid No steploos in 4hr Shift at 2800mm(min
Sculping
2500
2500
8000
12000
Sculping
- MarcoGaspar
12 Feb 2019 11:39 - 12 Feb 2019 11:46 #126260
by MarcoGaspar
Hello,
Do you have mesa 7i76e?
How do you wired your driver to mesa card?
I i have my hal file with hm2_7i76e.0.stepgen.00.step_type 0 the motor doesn't move if i put hm2_7i76e.0.stepgen.00.step_type 2 it moves but i have this problem with steps forward and backward.
The problem is the driver.... the motor... the 7i76e or the ballscrew?
Can you share your ini and hal file?
Replied by MarcoGaspar on topic Mesa 7I76E + HSS60 Driver parameters ------ losing stepps
The HSS60
2500
2500
8000
12000
Sculping
Hello,
Last edit: 12 Feb 2019 11:46 by MarcoGaspar.
12 Feb 2019 15:13 #126269
Replied by PCW on topic Mesa 7I76E + HSS60 Driver parameters ------ losing stepps
If it moves with type 2 (quadrature) but not type 0 (Step/Dir), its likely your step
times are too short or you have the step polarity wrong.
As a first try, I would select mode 0, double your step times and try again...
- MarcoGaspar
12 Feb 2019 15:48 #126275
by MarcoGaspar
If i chose mode 0 the motor stand still
12 Feb 2019 15:56 #126277
Did you double the step time?
- MarcoGaspar
12 Feb 2019 16:05 #126278
by MarcoGaspar
12 Feb 2019 16:07 #126280
Probably not, I would double the step time and step space and try again
- MarcoGaspar
12 Feb 2019 16:32 #126284
by MarcoGaspar
And 7I76e wired to the drive with dir+,dir-,puls+,puls- ?
12 Feb 2019 17:30 #126287
Yes that should work
I think a very important thing that's often missed here is that the drive timing numbers are _minimums_, that is, they are on the edge of not working at all, because of this you should never chose drive minimums as a starting point.
The following user(s) said Thank You: MarcoGaspar
Time to create page: 0.346 seconds
