7i92 pncconf
22 Feb 2019 14:23 #126917
by pl7i92
7i92 pncconf was created by pl7i92
Will there be a posible pncconf version that can handle the
Bitfiles in Directory or even coustm bitfiles as on readback from the board
22 Feb 2019 14:46 #126919
Replied by PCW on topic 7i92 pncconf
There's a experimental mode that reads the current IDROM from the bitfile
but I think it needs work...
22 Feb 2019 18:58 #126931
by pl7i92
Replied by pl7i92 on topic 7i92 pncconf
thanks is this from BigJohn github
22 Feb 2019 19:21 #126937
No its in pncconf, wriiten by Chris Morely
The "Discovery Option" may only be in master
23 Feb 2019 00:55 #126970
Replied by cmorley on topic 7i92 pncconf
Master and must check the 'Show advanced option pages' The you will see it on the Mesa configuration page/tab
As Peter mentions it's clunky and brittle.
Chris M
Chris M
24 Mar 2019 16:22 #129484
by pl7i92
so handmade configs are still the best option
24 Mar 2019 16:27 #129486
You can use pncconf 5i25 configurations for the 7I92 by just globally replacing the card name and replacing the driver load line, you don't really need to start completely from scratch.
The following user(s) said Thank You: DanielCNC
- Thank you received: 5945
24 Mar 2019 19:14 #129502
Replied by tommylight on topic 7i92 pncconf
Search and replace (ctrl+H) can make that a breeze !
26 Mar 2019 08:44 #129659
by pl7i92
woudent it be a great Releve to setup a Catagory here ,MAYBE 2nd state under configs
FOR Mesacards Basic
and make a post to start Sticky
FOR Mesacards Basic
Time to create page: 0.231 seconds
