Spindle not being enabled when running G-Code
09 Jun 2019 21:19 #136403
by HueyHQ
Spindle not being enabled when running G-Code was created by HueyHQ
I am now dangerously close to making sawdust, with the axes moving correctly, homing, and tool changing, but the spindle doesn't fire up when running G-Code. I expect this is something quite fundamental, but the reason escapes me.
I would expect the 7i77 spinena pin to turn on when M3 is executed, but it does not, as confirmed with a multimeter.
I can operate the spindle manually via halrun, so I'm fairly sure that confirms the hardware is OK.
I suspect that it is my toolchange subroutine at fault, or I haven't correctly looped my toolchange HAL pins, but this is where I get stuck.
Could someone please look over my config to see where I have made a mistake? Thank you in advance.
Jon
Jon
09 Jun 2019 21:28 - 09 Jun 2019 21:29 #136404
by Grotius
Replied by Grotius on topic Spindle not being enabled when running G-Code
@Mr, John Matrix,
This one is working :
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
And this one is not working :
#net spindle-enable <= spindle.0.on
#net spindle-cw <= spindle.0.forward
#net spindle-ccw <= spindle.0.reverse
It could be that the # sign has to be removed at some lines to activate the signal's.
In hal you activated the signal spindle-manual-cw manually i guess to start the spindle?
I think you are close indeed !!
Warning: Spoiler!
#net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
#net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
#net spindle-vel-cmd-rpm <= spindle.0.speed-out
#net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
#net spindle-brake <= spindle.0.brake
#net spindle-revs => spindle.0.revs
#net spindle-at-speed => spindle.0.at-speed
#net spindle-vel-fb-rps => spindle.0.speed-in
#net spindle-index-enable <=> spindle.0.index-enable
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
Last edit: 09 Jun 2019 21:29 by Grotius.
09 Jun 2019 21:50 #136406
Replied by PCW on topic Spindle not being enabled when running G-Code
Yes, basically, needed connections are commented out or
have incorrect names. try the connections below:
net spindle-output => hm2_5i25.0.7i77.0.1.analogout5
net spindle-enable => hm2_5i25.0.7i77.0.1.spinena
net spindle-output <= spindle.0.speed-out-abs
- Thank you received: 5945
09 Jun 2019 23:36 #136424
Replied by tommylight on topic Spindle not being enabled when running G-Code
Also add the S value after the M3 as depending on how it is set up in hal it will not work without it.
M3 S6000
M3 S6000
10 Jun 2019 09:52 #136453
by HueyHQ
Replied by HueyHQ on topic Spindle not being enabled when running G-Code
Thanks guys. I commented out that block because, at first glance, I thought they were all related to spindle encoder - should have looked more closely!
I'll give it go when I get home from my work trip. Can't wait, getting pumped about it!
Tommy: I looked into that, and consulted the G Code Overview -> Order of Execution , which I interpreted as the S value gets executed before the M3 regardless of order on the line - have I got that wrong? I am curious about the HAL setup you mention; is that something else I've done? But certainly something else I'll look at, cheers.Also add the S value after the M3 as depending on how it is set up in hal it will not work without it.
M3 S6000
11 Jun 2019 03:12 #136535
Linuxcnc can be set up to use Spindle_on that requires only M3 to run the spindle or spindle_CV /spindle_ccv that requires also the S value.
Also if you removed parts pertaining to spindle encoder, there should be a line that has to be changed so the feedback from it is looped to the spindle_at_speed pin, or you can test it by just setting spindle _at_speed to true.
11 Jun 2019 03:24 #136538
by HueyHQ
OK, thanks - I think I get it now (but we'll see).
Time to create page: 0.169 seconds
