firmware won't write on plug-n-go
23 Jul 2019 04:21 #140262
by rwistort
firmware won't write on plug-n-go was created by rwistort
Greetings!
I've been using a mesa plug-and-go 6i25 with 7i76. Everything worked as advertised. First time!
Seriously, folks... The 7i76 drives my steppers just fine, and now I need to add a 7i77 servo daughter-board to drive an analog servo amp, so I needed to update the firmware.
Mesaflash didn't work, so I compiled it from source. (I had to fix some sizeof() warnings and take out some 'inline' tags to get a clean compile. Seems like it shouldn't be that hard.) Then I tried to download the firmware:When I do
sudo ./mesaflash --device 5i25 --readhmid
and it shows stepgens on both P2 and P3, so I'm wondering if perhaps plug-n-go kits' pre-loaded firmware is write-protected?
How do I download a 7i77_7i76 config onto my 6i25?
Reid
> cd ~/mesa/5i25/utils/linux/source/mesaflash3
> sudo ./mesaflash --device 5I25 --write ~/mesa/5i25/configs/hostmot2/5i25_7i77_7i76.bit
Checking file... OK
File type: BIT file
Design name: TopPCIHostMot2b.ncd;UserID=0xFFFFFFFF
Part name: 6slx9tqg144
Design date: 2018/12/19
Design time: 13:14:07
Config Length: 340604
Erasing sector 0 for boot block
BootBlock installed[
Failed to write valid boot sector
Reid
23 Jul 2019 06:55 #140264
by pl7i92
Replied by pl7i92 on topic firmware won't write on plug-n-go
DID you jumper for the writing
look in the pdf to see jumper settings
23 Jul 2019 07:32 #140269
Replied by PCW on topic firmware won't write on plug-n-go
You should use the latest mesaflash from
github.com/micges/mesaflash/tree/v3.3
it looks like the old mesaflash may have corrupted the boot block
so make sure you re-write the firmware before cycling the power!
(note: there are no jumper settings related to flashing the 5I25 firmware)
23 Jul 2019 15:19 #140295
by rwistort
Replied by rwistort on topic firmware won't write on plug-n-go
Github did the trick. Thanks.
24 Jul 2019 03:45 #140387
by rwistort
If you're going to make one mistake, you might as well make them all, I always say.
Fixing the jumper helped too.
Time to create page: 0.263 seconds
