Homing X and Y can't jog after homing?
10 Apr 2020 17:37 #163514
Replied by cmorley on topic Homing X and Y can't jog after homing?
ok fix the x direction.
Then as for homing which way do you want it to travel searching for home?
ie, usually I think y would home with the the table moving towards you.
The following user(s) said Thank You: Catch22
10 Apr 2020 18:07 #163517
by Catch22
Replied by Catch22 on topic Homing X and Y can't jog after homing?
Ok so I have managed to get the homing all sorted out except after all 3 axis homes the x and y axis won't move when I try jogging them, the z axis jogs no problem. I'm wondering if it's not coming off of the limit switches far enough but I can't seem to find where to change that. If Infact that is the problem?
10 Apr 2020 18:43 #163520
This looks like a repost of your first post. Did you mean to send it?
10 Apr 2020 18:46 #163521
Replied by rodw on topic Homing X and Y can't jog after homing?
If you have shared HOME/LIMIT switches, you need to add a HOME-OFFSET in your ini file to move of the limit switch soit does not trigger a limit error as soon as homing completes.
10 Apr 2020 18:49 #163522
He does - .001 that's why it moved the ,001 when he jogged.
Chris
Chris
10 Apr 2020 18:52 #163523
Not seeing that in his config.
Chris
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = 0.100000
10 Apr 2020 18:53 #163524
Sorry a better way to say this is that the soft limit and home position are .001 apart. so there should be no problem.
he hasn't complained about an error message so being on limit switch is not the problem.
12 Apr 2020 13:06 #163751
by Catch22
Ok got it working now.
The problem was in axis configuration, I had the positive travel distance set to 10 and the negative travel distance set to 0
So I just had to reverse that and it now works.
Thanks for everyone's help.
12 Apr 2020 14:21 #163760
Well that doesn't sound right at all.
Time to create page: 0.101 seconds
