stepper settings/ calculation set up
04 May 2020 03:49 #166566
Replied by rodw on topic stepper settings/ calculation set up
Oops, sorry, I updated what I said. I've been immersed in this stuff with a US based engineer the last couple of days who is working in SI units. This morning he said:
Rod, in your distance traveled calc per pinion rev - my research showed that a 30mm diameter pinion is the pitch diameter. You guys are clever enough to call it by it's useful name
04 May 2020 07:02 #166579
by bbsr_5a
Replied by bbsr_5a on topic stepper settings/ calculation set up
you need the pitch of the belt system
there are Inch and Metric belts available
GT2 for instance is metric 2mm Metric is 5mm or 10mm Standard
the Inch ones are module m=d/z
but better to messure is the outside diameter m=da / 7(z+2)
and d=Workdiameter=m*z
worklengthPerRev= U = d*Pi THATS the Value you need for calculation
if you got the m you got P as m=P / Pi -> P= m * Pi
so you got
d= (z*P) / Pi
Sorry Education Personal
so you got
d= (z*P) / Pi
Time to create page: 0.073 seconds
