Automatically convert parallel port setup to 7i92=>DB25?
08 May 2020 17:43 #167062
by Maecki
Automatically convert parallel port setup to 7i92=>DB25? was created by Maecki
at the moment I have a parallel port driven 6040 at an old desktop pc's parallel port.
i ordered a 7i92 to connect the bob to and use a newer PC with ethernet to drive it.
Is there an automatic way to generate the 7i92 configuration/bitfile from the parport linuxcnc settings?
Tia
Maecki
Tia
Maecki
- Thank you received: 5944
08 May 2020 18:27 - 08 May 2020 18:27 #167068
Last edit: 08 May 2020 18:27 by tommylight.
The following user(s) said Thank You: Maecki
09 May 2020 06:57 #167113
by bbsr_5a
Replied by bbsr_5a on topic Automatically convert parallel port setup to 7i92=>DB25?
better is to use a complete new Setup from the configuration tool to get better and faster movement on your timing
the 7i92 uses HARDware stepper from Board
the parport is a computer/PC based timing
you will be impressed what the machine is capable of
Time to create page: 0.135 seconds
