lathe spindle encoder/7i76e setup
18 May 2020 21:14 #168190
by kulgan17
lathe spindle encoder/7i76e setup was created by kulgan17
how would one verify an encoder has been properly set-up? encoder position in the open loop test gives a feedback of .004 per turn and none of the hal meter rps or rpm gives what I would expect, very small numbers. using encoder hedl 5640 a13 500ppr.
18 May 2020 21:37 - 18 May 2020 21:37 #168193
Replied by PCW on topic lathe spindle encoder/7i76e setup
If you don't get 2000 raw counts per turn with a 500 PPR encoder. its
likely that there is an electrical/wiring issue, possibly a mismatch between
7I76E encoder type settings and your encoder or a wiring error.
Last edit: 18 May 2020 21:37 by PCW.
19 May 2020 02:14 #168222
by kulgan17
Replied by kulgan17 on topic lathe spindle encoder/7i76e setup
Thanks for your reply, wiring was good. Turns out that the encoder is very sensitive to how its mounted.
Time to create page: 0.130 seconds
