parameter or pin 'hm2_7i76e.0.watchdog.timeout_ns' not found
28 May 2020 19:10 #169241
by msageryd
I installed LCNC 2.8 which has 7i96 support in pncconf. Made a rough config and tried to start LCNC. Got a weird error about a missing pin. It seems like the board is found, though.
I'm totally new to LCNC, this was a rough start.
From the error report:
From the HAL file:
From the ini file:
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:16:01:71
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Smart Serial Firmware Version 43
hm2/hm2_7i96.0: 51 I/O Pins used:
./HighZ.hal:10: parameter or pin 'hm2_7i76e.0.watchdog.timeout_ns' not found
From the HAL file:
setp [HMOT](CARD0).watchdog.timeout_ns 5000000
From the ini file:
[HMOT]
CARD0=hm2_7i76e.0
- Thank you received: 5944
28 May 2020 19:40 #169245
Replied by tommylight on topic parameter or pin 'hm2_7i76e.0.watchdog.timeout_ns' not found
Does 7i76E have field power applied ?
28 May 2020 19:44 - 28 May 2020 19:44 #169246
Replied by PCW on topic parameter or pin 'hm2_7i76e.0.watchdog.timeout_ns' not found
Did you select 7i96 in pncconf?
I just tested with the latest version of 2.8 and its OK
Did you try updating to the latest 2.8 version?
Last edit: 28 May 2020 19:44 by PCW.
28 May 2020 19:52 - 28 May 2020 19:52 #169248
The error says 7i76e, the rest is 7i96, so just replacing the 7i76e with 7i96 in the hal file should do the trick.
Must be going blind....From the error report:
hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:16:01:71 hm2_eth: discovered 7I96 hm2/hm2_7i96.0: Smart Serial Firmware Version 43 hm2/hm2_7i96.0: 51 I/O Pins used: . . ./HighZ.hal:10: parameter or pin 'hm2_7i76e.0.watchdog.timeout_ns' not found
Last edit: 28 May 2020 19:52 by tommylight.
28 May 2020 19:53 #169249
by msageryd
Replied by msageryd on topic parameter or pin 'hm2_7i76e.0.watchdog.timeout_ns' not found
@tommylight: Yes, and thanks!!
When I read your question I got confused. I don't have a 7i76, but a 7i96.
It's probably a bug in the new pncconfig which leaves the wrong device name in the ini file. I corrected the name and now it works.
From the corrected ini file:
[HMOT]
CARD0=hm2_7i96.0
28 May 2020 19:54 #169250
This does seem to be fixed in the latest 2.8 (at least it works for me)
28 May 2020 20:01 #169251
by msageryd
I'm at build 5914 which I installed yesterday.
28 May 2020 20:15 #169253
Maybe it a buildbot thing but I just fetched and rebuilt and there is no issue
The following user(s) said Thank You: msageryd
28 May 2020 21:45 #169256
Walks like a duck, quacks like a duck, it s a duck !
The title said 7i76e, the error said the same thing, so i came to the conclusion you have a 7i76e!@tommylight: Yes, and thanks!!
29 May 2020 06:30 #169268
by Clive S
I think you are understanding English too well now Tom:woohoo:
Replied by Clive S on topic parameter or pin 'hm2_7i76e.0.watchdog.timeout_ns' not found
Time to create page: 0.119 seconds
