Test Panel - inop - no function?
31 May 2020 19:43 #169559
by MikeWien
Replied by MikeWien on topic Test Panel - inop - no function?
Ah, ok.. was not clear... I expected
on the Axis page the "Test/Tune axis" to see tests /tuning for axis , and on the previous page . i/o connector ... "launch test panel" a panel where I can play with all input / output pins...
31 May 2020 20:11 #169564
Replied by PCW on topic Test Panel - inop - no function?
Ahh, the per axis test/tune option is present and work in the master version
of pncconf but a general I/O test panel launcher is not present.
For axis tuning "calibrate" is probably the best way and halshow/halcmd are
probably the best way to observer/modify hal pins and parameters
The following user(s) said Thank You: MikeWien
Time to create page: 0.063 seconds
