Not sure where to ask so, so I'll ask here
12 Jun 2020 09:38 #171231
by Desertboy
Not sure where to ask so, so I'll ask here was created by Desertboy
Hi, I have a Mesa 5i25 PCI card I would now like to use for a simple 3 axis router.
What BOB should I buy?
I have 4 Nema's 2 on the Y, 1 on X and 1 on Z I would like to setup dual homing.
Looking at the choices I think I could use a 7i78 for step/dir/spindle and a cheap PP BOB for limits and MPG
Or get a 7i76 but they are out of stock, which I think can handle all my inputs and step/dir.
If I wanted to add Nema 23's with encoders is that what 7i85 is for? And can you plug both 7i76 and 7i85 in at the same time?
I'm thinking 7i85 lets you use encoders with any stepper drivers by moving the encoding to the Mesa is this correct?
12 Jun 2020 12:50 #171250
Replied by PCW on topic Not sure where to ask so, so I'll ask here
7i76s are in stock now.
The common "5 Axis" parallel port BOB
does have a analog spindle interface ,though its not
isolated since its power is in common with the inputs
In general the multiple encoder interfaces are mainly useful
if you have dual feedback or servo systems, not so much for
using encoder feedback from a step drive.
The following user(s) said Thank You: Desertboy
18 Jun 2020 19:46 #172034
by Desertboy
Replied by Desertboy on topic Not sure where to ask so, so I'll ask here
I ordered one now.
Will I need to flash the 5i25? It's got the stock firmware with it it's essentially new although I've had it over 2 years.
Do I just need a normal parallel port cable to connect the 5i25 to the 7i76?
18 Jun 2020 21:08 #172040
I would reprogram the 5I25 with 5i25_7i76x2.bit just to make sure
You can use a standard IEEE1284 male-male parallel port cable
19 Jun 2020 06:30 #172056
by Desertboy
I have 2 MPG's I can use
HB04 USB
or standard multiwire Chinese special
The HB04 has more buttons which would be very useful but I read is less reliable.
Which one would you use?
HB04 USB
19 Jun 2020 06:34 #172057
by Desertboy
One of the reasons I didn't use the 5i25 was the pc wouldn't boot with it in.
I had a DDCSV to hand.
I later traced the PC not booting to a PSU issue, Mesa told me a very small % had this issue and was a MB issue but I tried 5 different MB's before I swapped the PSU in that case.
As soon as I did swap the PSU 5i25 worked with 3 of the MB's didn;t try the other 2.
So if you ever see someone with a 5i25 PCI that won't boot tell them to swap the PSU first.
19 Jun 2020 06:55 #172059
by Desertboy
I bought this one
mesaus.com/product/7i76/
7i76 not the 7i76D, I have AM882's which you can set the rising edge is this what the difference between the 7i76 and the 7i76D?
19 Jun 2020 07:03 - 19 Jun 2020 07:15 #172060
by Clive S
Its here in the manual page one. www.mesanet.com/pdf/parallel/7i76man.pdf
Edit: And for the MPG's see this forum.linuxcnc.org/media/kunena/attachme...hluss_2017-01-02.pdf
Replied by Clive S on topic Not sure where to ask so, so I'll ask here
I bought this one
Last edit: 19 Jun 2020 07:15 by Clive S. Reason: added text
19 Jun 2020 07:47 #172061
Replied by rodw on topic Not sure where to ask so, so I'll ask here
The 7i76 supports stand alone MPG knobs not USB pendants which may or may not have Linuxcnc support.
19 Jun 2020 08:13 #172062
by Desertboy
I've had the USB pendant working in linuxcnc before although it was a PITA
this was 2017 so hoping it's a bit easier now.
I could probably get both working side by side which might not be a bad idea.
Time to create page: 0.129 seconds
