Mesa connection issue
10 Jul 2020 01:48 - 10 Jul 2020 02:08 #174168
by KaleD
Mesa connection issue was created by KaleD
I'm in linuxcnc 2.8 setting up a 7i96. I followed this tutorial: forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
when I try to launch my PlasmaC config I get an error reading:
ERROR: Failed to execute '/sbin/sysctl -q net.ipv6.conf.eth0:avahi.disable_ipv6=1
in the debug info it states:
sysctl: cannot stat /proc/sys/net/ipv6/conf/eth0:avahi/disable_ipv6: No such file or directory
I can ping 10.10.10.10 successfully and my base machine opens fine.
I've been trying for a while to narrow down the problem. Any help would be greatly appreciated.
Last edit: 10 Jul 2020 02:08 by KaleD. Reason: Clarity
10 Jul 2020 02:08 #174171
Replied by PCW on topic Mesa connection issue
What does
ip a
print?
ip a
print?
10 Jul 2020 02:13 #174172
by KaleD
Replied by KaleD on topic Mesa connection issue
10 Jul 2020 02:18 - 10 Jul 2020 02:19 #174173
Right, so you have not setup a static IP address for the host.
Take a look an the hm2_eth manual page for how to do this in the interfaces file
Last edit: 10 Jul 2020 02:19 by PCW.
10 Jul 2020 02:20 #174174
by KaleD
Are you referring to this:
linuxcnc.org/docs/html/man/man9/hm2_eth.9.html
10 Jul 2020 02:24 #174175
Yes, you can also use the GUI to set up a static IP address on the host
(10.10.10.100 suggested)
The interfaces file method has the advantage of being able to change
driver settings (such at the setting required by Intel MACs for real time)
10 Jul 2020 02:29 #174177
by KaleD
I can't save the interfaces file with the changes. I'm using mousepad.
10 Jul 2020 02:54 - 10 Jul 2020 02:54 #174179
you need to be root to edit most system files
so
sudo mousepad
so
sudo mousepad
Last edit: 10 Jul 2020 02:54 by PCW.
10 Jul 2020 03:08 - 10 Jul 2020 03:09 #174180
by KaleD
Ok, thanks. I'm only a few months old as a linux user. I made the interfaces file changes.
I now get an error stating that the network is unreachable.
Last edit: 10 Jul 2020 03:09 by KaleD. Reason: +info
10 Jul 2020 03:13 #174181
OK what does
ip a
report now?
and whats in the interfaces file?
ip a
report now?
Time to create page: 0.120 seconds
