Huanyang VFD and Mesa 7i76e stuck at 6000 rpm
21 Jul 2020 10:40 - 21 Jul 2020 10:40 #175326
by Stran_ge
Replied by Stran_ge on topic Huanyang VFD and Mesa 7i76e stuck at 6000 rpm
I edited the Spindle part of my hal as following:
When i start my spindle it starts at 9xxx rpm instead of 6000 when i type M3 S24000 i only reach 22xxx rpm and for everything else the values are higher than what i typed in.
This is the Spindle part of my Ini:
I will attach the full hal and ini aswell.
loadrt timedelay count=1
loadrt lincurve personality=4
addf timedelay.0 servo-thread
addf lincurve.0 servo-thread
setp timedelay.0.on-delay 4
setp timedelay.0.off-delay 0
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
# ---auto rpm: 1-6000 = 6000 / 24000 max
setp lincurve.0.x-val-00 0
setp lincurve.0.y-val-00 0
setp lincurve.0.x-val-01 1
setp lincurve.0.y-val-01 6000
setp lincurve.0.x-val-02 6000
setp lincurve.0.y-val-02 6000
setp lincurve.0.x-val-03 24000
setp lincurve.0.y-val-03 24000
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm-abs => pid.s.command
net spindle-vel-fb-rpm-abs => pid.s.feedback
net spindle-output <= pid.s.output
# ---digital potentionmeter output signals/setup---
setp hm2_7i76e.0.7i76.0.0.spinout-minlim [SPINDLE_0]OUTPUT_MIN_LIMIT
setp hm2_7i76e.0.7i76.0.0.spinout-maxlim [SPINDLE_0]OUTPUT_MAX_LIMIT
setp hm2_7i76e.0.7i76.0.0.spinout-scalemax [SPINDLE_0]OUTPUT_SCALE
net spindle-output => hm2_7i76e.0.7i76.0.0.spinout
net spindle-enable => hm2_7i76e.0.7i76.0.0.spinena
net spindle-ccw => hm2_7i76e.0.7i76.0.0.spindir
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-pre <= spindle.0.speed-out-abs lincurve.0.in
net spindle-vel-cmd-rpm-abs <= lincurve.0.out
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-at-speed => spindle.0.at-speed timedelay.0.out
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
#sets spindle-at-speed true
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 24000.0
OUTPUT_SCALE = 26000
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 24000
Last edit: 21 Jul 2020 10:40 by Stran_ge.
21 Jul 2020 13:43 - 21 Jul 2020 14:35 #175334
by Stran_ge
I cant be doing everything wrong here , is everyone else controlling their vfd via modbus ??
Last edit: 21 Jul 2020 14:35 by Stran_ge.
21 Jul 2020 14:52 #175338
Replied by PCW on topic Huanyang VFD and Mesa 7i76e stuck at 6000 rpm
It sounds like the drive runs at 6000 RPM for 0V input
if so the lincurve values are wrong since you want a
Y value (output) of 0 at a commanded RPM of 6000
Also if you have a output scale of 26000 and a maxoutput of 24000
you can never get full output (these should both be left at 24000)
21 Jul 2020 15:12 - 21 Jul 2020 15:12 #175340
by Stran_ge
the thing is at m3 s1 where it shouldnt be turning i measure 0.03v and get perfect 6000 rpm
at m3 s6000 i get 2.3 v and 10300 rpm and at m3 s7000 i get 2.7 volt and 11000 rpm
i already changed that output scale back to 24000 but it didnt change anything
Last edit: 21 Jul 2020 15:12 by Stran_ge.
21 Jul 2020 15:19 #175341
Right, so your linscale values are wrong,
Y should be 0 when X is 6000, you have that backwards
21 Jul 2020 15:26 #175343
by Stran_ge
so it should be this way:
setp lincurve.0.x-val-01 6000
setp lincurve.0.y-val-01 0
21 Jul 2020 15:31 - 21 Jul 2020 15:32 #175344
Point 02 is wrong and will cause you to get about 2.5V with a 6000 RPM command instead of 0V
Do you get 24000 RPM at 10V?
Last edit: 21 Jul 2020 15:32 by PCW.
21 Jul 2020 15:34 - 21 Jul 2020 15:38 #175345
by Stran_ge
the maximum is 23xxx rpm at 9.1 volt
Last edit: 21 Jul 2020 15:38 by Stran_ge.
21 Jul 2020 15:40 #175346
So you really only need 3 points for lincurve (you could actually do the same thing with the scale component since you are just offsetting the analog output by 6000 )
setp lincurve.0.x-val-02 24000
setp lincurve.0.y-val-02 24000
The following user(s) said Thank You: Stran_ge
21 Jul 2020 15:48 - 21 Jul 2020 15:51 #175347
by Stran_ge
i changed the hal part and now when i start the spindle it starts at 6000 but i cant change the speed anymore.
I can start stop and change direction nothing else.
The Output voltage stays the same whatever i input via m3 sxxxxx
i appreciate the help so far, im trying to get this working correctly for the past 2 days
Last edit: 21 Jul 2020 15:51 by Stran_ge.
Time to create page: 0.202 seconds
