how to install mesaflash
28 Jul 2020 00:46 #176193
Replied by PCW on topic how to install mesaflash
Board not found is different than file not found
It means that the 5i25 card was not detected
28 Jul 2020 04:13 #176208
by ericg
Replied by ericg on topic how to install mesaflash
Ok, slowly getting there, I had a permissions problem now fixed, and a problem between the ears, got it running but now I have to work out why I cannot get the GUI out of stop
28 Jul 2020 06:54 #176214
by ericg
another problem solved,, there was an open circuit in the e-stop line causing the G540 to fault condition, that and a correction in the e-stop gpio pin (was 16 but should have been 3),
Linuxcnc with mesa card now working almost OK, the 3 axis are homing and it will run a program, but the spindle is not turning on under program control, that's the next step, followed by the touch probe and remote pendant control.
feel a bit happier now
28 Jul 2020 13:02 #176241
Too late to help, but the answer is probably:
in addition to the buildbot repo:
www.linuxcnc.org/dists/buster/base/binary-amd64/
You will need the www.linuxcnc.org archive signing key, but may well already have it.
If you look through the files in buildbot.linuxcnc.org/dists you will see that mesaflash is in "base" not "master-rtpreempt"
Replied by andypugh on topic how to install mesaflash
Hi, this should be simple but not, I have in my sources.list ... deb buildbot.linuxcnc.org/ buster buster master-rtpreempt, and then invoked sudo apt install mesaflash, but it is not found, can someone tell me where to get it?
deb http://www.linuxcnc.org/ buster base
- Thank you received: 5934
28 Jul 2020 15:08 #176254
Replied by tommylight on topic how to install mesaflash
What happened to Eric ?
28 Jul 2020 17:50 #176262
I don't know. He appears to have been banned, but I can't think why. (It wasn't me)What happened to Eric ?
28 Jul 2020 18:28 #176271
Ericg I have unbanned you, but I suspect that the problem is a bouncing (exemail) email address.
29 Jul 2020 10:19 - 29 Jul 2020 12:03 #176345
by ericg
I got banned somehow??? possibly due to me forgetting to change my email address a long time ago,
Many thanks to Andy Pugh for sorting it out.
Now I sorted the spindle control out but I may need to ask about scaling, it does work it runs Ok but the PyVcp panel shows it running well above it's actual speed, and I have an issue with the touch probe to which I think I have the answer, I will continue this saga tomorrow.
Thanks all for your help.
Last edit: 29 Jul 2020 12:03 by ericg. Reason: grammer error
29 Jul 2020 12:10 #176372
Welcome back.
Check in hal if the PyVCP is using
.....spindle.abs.rps
or
.....spindle.abs.rpm
it should use rpm
or
it should use rpm
29 Jul 2020 12:24 #176374
by ericg
Perhaps I don't have things set up correctly, I have pyvcp_options.hal and it has 2 lines in it
net spindle-vel-cmd-rpm-abs => pyvcp.spindle-speed
net spindle-at-speed => pyvcp.spindle-at-speed-led
and in custom_postgui.hal
sets spindle-at-speed true
nothing in the main hal file
Have I got things muddled?
