Mesa 7i76E first try
10 Aug 2020 15:11 #177824
by Jocman
Mesa 7i76E first try was created by Jocman
Hi all.
Finally today i finished the bench wiring,and tried to make a first attempt with pncconf.
The card is connected with the pc via ethernet and working.
I'm following the guide i found on linxcnc site.
I see that the screens i see don't match the screenshots on the guide (i'm using the current version of linuxcnc).
Btw,i went on,by naming my machine and choosing axis and units.
From the dropdown list,i choosed the 7i76e (as it is present in the list),then set the stepgen (0=X,1=Y,2=Z) (but the button Start Test Panel doesn't do anything),then went to the X motor panel.
Right now,i've only 1 motor on my bench,wired to bank 0 for the stepgen (X).
But when i try to run the Test Tuning Axis,after enabling and pushing Start,nothing happens. The motor don't rotate.
I double checked the wiring and i realized I inverted pulse with dir and viceversa; after fixing the wrong wiring,tested again,but nothing again.
The motor is working (the rotor mast is blocked and it goes warm) but no sign of life.....
Only En+ and En- aren't wired,but i think they're not mandatory.
Any suggestion?
Andrea
Any suggestion?
Andrea
10 Aug 2020 15:14 #177825
Replied by PCW on topic Mesa 7i76E first try
The most common reason for lack of motion is wiring or too short step pulse lengths
10 Aug 2020 15:30 #177826
by Jocman
Replied by Jocman on topic Mesa 7i76E first try
Double checked again and the wirings are correct.
My stupid question: where to set the step pulse lenght?
10 Aug 2020 16:33 #177827
It would be the Step-On time on the X Motor, Y Motor etc pages
10 Aug 2020 17:47 #177829
by Jocman
Well,just the places where i cheked....
I put in several values,even following your suggestion given in another post as starting point when the values are unknown:
5000 steplength
5000 stepspace
20000 dirsetup
20000 dirhold
Unfortunately it wouldn't accept more than 5000 each fields,but even inserting 5000 in each field,then trying lowering the values,the motor still don't move....
5000 steplength
5000 stepspace
20000 dirsetup
20000 dirhold
10 Aug 2020 17:49 #177830
Did you try running the pncconf created configuration?
10 Aug 2020 18:39 #177834
by Jocman
Honestly,as nothing moved i quit pncconfig without going on with the other axis....
Well,tomorrow when i back from work (in a while i'll go to sleep) i'll try to complete the wizard procedure and see what happen....
11 Aug 2020 18:18 #177918
by Jocman
Ok I did the full pncconf procedure and started Linuxcnc. But I got an error message (see attacheg log.txt).
As I understand, I've an issue with Preempt-RT kernel (so as I found on other post in the forum).
If I'm right, I've installed Linuxcnc Debian Wheezy, so I tried to follow the steps found on Linuxcnc website to install Preempt-RT kernel.
But this time the system tells me there's nothing to update.
Well, don't know what to do now....
- Thank you received: 5944
11 Aug 2020 18:40 #177919
Replied by tommylight on topic Mesa 7i76E first try
You need the Stretch version of LinuxCNC for Mesa ethernet boards.
Get it in the downloads section of the main Linuxcnc page.
linuxcnc.org/downloads/
- dvn4life1972
- Thank you received: 168
11 Aug 2020 19:05 #177924
by dvn4life1972
Did you select "Custom" for the stepper? I'm pretty sure it won't allow value changes, or at least only a very limited range, unless custom is selected.
Replied by dvn4life1972 on topic Mesa 7i76E first try
Time to create page: 0.157 seconds
