Square Gantry without customizing ini
26 Sep 2020 05:40 #183793
by jfuerst
Square Gantry without customizing ini was created by jfuerst
I square my gantry by utilizing the HOME_OFFSET tag in the ini:
[JOINT_0]
HOME_OFFSET = 0.1
JOINT_1
HOME_OFFSET = 0.137
Is there some way, or place that I can move these that will preserve them after running PnCConf? As you know the ini is re-written when you run PnCConfig. Is there a way in some "permanent" file to move the joints independently the required amount after homing?
Thanks!
[JOINT_0]
HOME_OFFSET = 0.1
JOINT_1
HOME_OFFSET = 0.137
Thanks!
26 Sep 2020 05:48 #183795
Replied by cmorley on topic Square Gantry without customizing ini
Currently - no.
26 Sep 2020 19:03 #183868
a future update 0f 2.8 will have this in place. master has it now.
Chris
Chris
