ppnconf - "Create simulated hw conf" missing
09 Jan 2021 16:17 - 09 Jan 2021 16:25 #194603
by Fiury
ppnconf - "Create simulated hw conf" missing was created by Fiury
Last edit: 09 Jan 2021 16:25 by Fiury.
- Thank you received: 5944
09 Jan 2021 16:40 #194611
Replied by tommylight on topic ppnconf - "Create simulated hw conf" missing
Is that Mint 19.3 ?
Most probably something with the theme used by Mint, so go to preferences>appearance> and choose a different theme.
Had the same issue with sheetcam, i could not see over half of settings.
In your case can also be due to the use of different language, is Linux Mint in English?
09 Jan 2021 16:53 - 09 Jan 2021 17:09 #194616
by Fiury
Replied by Fiury on topic ppnconf - "Create simulated hw conf" missing
Mint 19.3 Tricia ,
reinstaled linuxcnc-uspace
changed 3 themes
not help..
language cz , Iwill try to switch to eng
edited
ok instled eng, switched...... not help :/
There is also pop up window , that i have no hasmot2 firmware downlowded in folder :
/lib/firmware/hm2/
PNCconf will use internal firmware data
- but this pop up is after i click to forward from main screen, this will be not this problem i think so..
Edited
what is fun, that in Stepconf is all, but Pncconf missing..
in StepconfWizard is all.
changed 3 themes
not help..
edited
/lib/firmware/hm2/
Edited
Last edit: 09 Jan 2021 17:09 by Fiury.
09 Jan 2021 17:06 #194620
Oops, there is no simulated in pncconf, sorry for that.
Turns out you are using a non real time kernel so LinuxCNC can run only in simulation mode.
Did you install the RT kernel?
If yes, reboot, hold down the shift key till the grub menu shows up, choose advanced opions and there choose a name with RT in it, press enter.
To check the kernel in use, in a terminal:
uname -a
uname -a
09 Jan 2021 17:12 #194621
by Fiury
Linux CNC 5.4.0-60-generic #67~18.04.1-Ubuntu SMP Tue Jan 5 22:01:05 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
09 Jan 2021 17:20 #194625
Nope, that is the normal generic kernel, reboot and check if you have anything with preempt-rt or RT in the name.
09 Jan 2021 17:33 #194627
by Fiury
Thank for help , just installing RT19.1
gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html
Hope that it will fix the problem.. i will wrote ..
Thanks for support !!
09 Jan 2021 18:26 #194631
Use this, it is much faster to install
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
Or use the official install instructions:
linuxcnc.org/downloads/
09 Jan 2021 20:12 - 09 Jan 2021 20:24 #194640
by Fiury
Afrter 3 hours of instaling RT Kernell ....... same problem with RT Kernall
Edited
Then reinstaled linuxcnc-uspace after kernell and WORKING !!!
THANKS !
Edited
THANKS !
Last edit: 09 Jan 2021 20:24 by Fiury.
10 Jan 2021 11:42 - 14 Jan 2021 06:38 #194713
by Fiury
Hmm , ok, something it is doing, but :
I have max 0-0,1 V output from Pin 2 :/ ... VDF show 2 Hrz
(Mesa 7i76ED).............................VDF HY
Last edit: 14 Jan 2021 06:38 by Fiury.
Time to create page: 0.134 seconds
