ppnconf - "Create simulated hw conf" missing
11 Jan 2021 00:14 #194822
Replied by andypugh on topic ppnconf - "Create simulated hw conf" missing
What does HAL show for the value going in to the ...analogout0 pin in HAL?
The 0.1V is measured with a multimeter at the Mesa terminals?
Do you also measure 10V there?
12 Jan 2021 08:11 - 14 Jan 2021 14:26 #195023
by Fiury
Replied by Fiury on topic ppnconf - "Create simulated hw conf" missing
Do you also measure 10V there? ..... OK
Not giving 0-10 (measured with a multimeter) , but oly 1.1-1,4 at the Mesa terminals?
ACM to Pin 1
VI to Pin 2
+10 to Pin 3
nothing to Pin 4
DCM to 5
FOR to Pin 6
DCM to Pins 7
REV to Pin 8
Configured VFD HY
PD001 = 1...OK
PD002 = 1 .......(but Hrz still can be set only manualy on VFD)
PD044 = 1.....OK
PD045 = 5.... OK
Can you check it pls?
(axis are not set pls check only spindle setup)
ACM to Pin 1
VI to Pin 2
+10 to Pin 3
nothing to Pin 4
DCM to 5
FOR to Pin 6
DCM to Pins 7
REV to Pin 8
Configured VFD HY
PD001 = 1...OK
PD044 = 1.....OK
PD045 = 5.... OK
Last edit: 14 Jan 2021 14:26 by Fiury.
Time to create page: 0.109 seconds
