RPI4 + 7C81 + DMB4250-8B BreakOut Board
01 Mar 2021 00:04 #200487 by cmorley
hmm that doesn't look like the usual --readhmid output.
Pncconf can try to piece together internal data from a --readhmid --sserial output.
01 Mar 2021 00:22 - 01 Mar 2021 00:24 #200489 by PCW
That's the hm2 driver startup output
If the OP doesn't post a pinout file, I can do it tomorrow
(don't have a 7C81 or RPI at home, and stopping by work
this close to dinner time was vetoed by the boss)
Last edit: 01 Mar 2021 00:24 by PCW.
01 Mar 2021 00:32 #200491 by cmorley
Happy wife - happy life!
01 Mar 2021 06:04 #200507 by brianvg
Here is what I get with the --readhmid command:
mesaflash --device 7C81 --spi --addr /dev/spidev0.0 --readhmid
unable to set bpw32, fallback to bpw8
Configuration Name: HOSTMOT2
  BoardName : MESA7C81
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 3
  Width of one I/O port: 19
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: QCount
  There are 2 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: StepGen
  There are 8 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: PWM
  There are 2 of PWM in configuration
  Version: 0
  Registers: 5
  BaseAddress: 4100
  ClockFrequency: 200.000 MHz
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P1+Serial
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 0      0   IOPort       PWM              0        PWM             (Out)
 0      1   IOPort       None
 0      2   IOPort       StepGen          0        Dir/Table2      (Out)
 0      3   IOPort       None
 0      4   IOPort       StepGen          0        Step/Table1     (Out)
 0      5   IOPort       None
 0      6   IOPort       StepGen          1        Dir/Table2      (Out)
 0      7   IOPort       None
 0      8   IOPort       StepGen          1        Step/Table1     (Out)
 0      9   IOPort       StepGen          2        Dir/Table2      (Out)
 0     10   IOPort       StepGen          2        Step/Table1     (Out)
 0     11   IOPort       StepGen          3        Dir/Table2      (Out)
 0     12   IOPort       StepGen          3        Step/Table1     (Out)
 0     13   IOPort       None
 0     14   IOPort       QCount           0        Quad-A          (In)
 0     15   IOPort       QCount           0        Quad-B          (In)
 0     16   IOPort       QCount           0        Quad-IDX        (In)
 0     17   IOPort       SSerial          0        TXData0         (Out)
 0     18   IOPort       SSerial          0        TXData1         (Out)
IO Connections for P2+Serial
 0     19   IOPort       PWM              1        PWM             (Out)
 0     20   IOPort       None
 0     21   IOPort       StepGen          4        Dir/Table2      (Out)
 0     22   IOPort       None
 0     23   IOPort       StepGen          4        Step/Table1     (Out)
 0     24   IOPort       None
 0     25   IOPort       StepGen          5        Dir/Table2      (Out)
 0     26   IOPort       None
 0     27   IOPort       StepGen          5        Step/Table1     (Out)
 0     28   IOPort       StepGen          6        Dir/Table2      (Out)
 0     29   IOPort       StepGen          6        Step/Table1     (Out)
 0     30   IOPort       StepGen          7        Dir/Table2      (Out)
 0     31   IOPort       StepGen          7        Step/Table1     (Out)
 0     32   IOPort       None
 0     33   IOPort       QCount           1        Quad-A          (In)
 0     34   IOPort       QCount           1        Quad-B          (In)
 0     35   IOPort       QCount           1        Quad-IDX        (In)
 0     36   IOPort       SSerial          0        TXEn0           (Out)
 0     37   IOPort       SSerial          0        TXEn1           (Out)
IO Connections for P7+Serial
 0     38   IOPort       None
 0     39   IOPort       None
 0     40   IOPort       None
 0     41   IOPort       None
 0     42   IOPort       None
 0     43   IOPort       None
 0     44   IOPort       None
 0     45   IOPort       None
 0     46   IOPort       None
 0     47   IOPort       None
 0     48   IOPort       None
 0     49   IOPort       None
 0     50   IOPort       None
 0     51   IOPort       None
 0     52   IOPort       None
 0     53   IOPort       None
 0     54   IOPort       None
 0     55   IOPort       SSerial          0        RXData0         (In)
 0     56   IOPort       SSerial          0        RXData1         (In)
01 Mar 2021 14:31 #200695 by PCW
If you update mesaflash to the latest, it should print out the DB25 pin numbers in the first column.
01 Mar 2021 14:49 #200699 by brianvg
Ok, checked out the repo and built it, then it produces this output:
./mesaflash --device 7C81 --spi --addr /dev/spidev0.0 --readhmid
  FPGA Size: 9 KGates
  FPGA Pins: 144
  IDROM Type: 3
  Module: DPLL
  Version: 0
  Registers: 7
  BaseAddress: 7000
  Module: WatchDog
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: QCount
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Module: StepGen
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: PWM
  Version: 0
  Registers: 5
  BaseAddress: 4100
  Module: LED
  Version: 0
  Registers: 1
  BaseAddress: 0200
P1 1                    0   IOPort       PWM              0        PWM             (Out)
P1 14                   1   IOPort       None
P1 2                    2   IOPort       StepGen          0        Dir/Table2      (Out)
P1 15                   3   IOPort       None
P1 3                    4   IOPort       StepGen          0        Step/Table1     (Out)
P1 16                   5   IOPort       None
P1 4                    6   IOPort       StepGen          1        Dir/Table2      (Out)
P1 17                   7   IOPort       None
P1 5                    8   IOPort       StepGen          1        Step/Table1     (Out)
P1 6                    9   IOPort       StepGen          2        Dir/Table2      (Out)
P1 7                   10   IOPort       StepGen          2        Step/Table1     (Out)
P1 8                   11   IOPort       StepGen          3        Dir/Table2      (Out)
P1 9                   12   IOPort       StepGen          3        Step/Table1     (Out)
P1 10                  13   IOPort       None
P1 11                  14   IOPort       QCount           0        Quad-A          (In)
P1 12                  15   IOPort       QCount           0        Quad-B          (In)
P1 13                  16   IOPort       QCount           0        Quad-IDX        (In)
P5 3,6                 17   IOPort       SSerial          0        TXData0         (Out)
P6 3,6                 18   IOPort       SSerial          0        TXData1         (Out)
P2 1                   19   IOPort       PWM              1        PWM             (Out)
P2 14                  20   IOPort       None
P2 2                   21   IOPort       StepGen          4        Dir/Table2      (Out)
P2 15                  22   IOPort       None
P2 3                   23   IOPort       StepGen          4        Step/Table1     (Out)
P2 16                  24   IOPort       None
P2 4                   25   IOPort       StepGen          5        Dir/Table2      (Out)
P2 17                  26   IOPort       None
P2 5                   27   IOPort       StepGen          5        Step/Table1     (Out)
P2 6                   28   IOPort       StepGen          6        Dir/Table2      (Out)
P2 7                   29   IOPort       StepGen          6        Step/Table1     (Out)
P2 8                   30   IOPort       StepGen          7        Dir/Table2      (Out)
P2 9                   31   IOPort       StepGen          7        Step/Table1     (Out)
P2 10                  32   IOPort       None
P2 11                  33   IOPort       QCount           1        Quad-A          (In)
P2 12                  34   IOPort       QCount           1        Quad-B          (In)
P2 13                  35   IOPort       QCount           1        Quad-IDX        (In)
P5 TXEN                36   IOPort       SSerial          0        TXEn0           (Out)
P6 TXEN                37   IOPort       SSerial          0        TXEn1           (Out)
Which looks very much like what I expect. I suppose I will need to generate the configuration, and then besides changing the board name and the command, I will need to also change the pin mappings after I run through pncconf. Still not really sure what I need to enter and where in pncconf.
Thanks,
Brian
Time to create page: 0.079 seconds
