Gantry System reversing direction of Motor on y2
- Creative25
14 Mar 2021 17:14 #202229
by Creative25
Gantry System reversing direction of Motor on y2 was created by Creative25
I am trying to test my setup for a gantry system. So I want Stepper Motors of y and y2 to move in opposite direction. Is this done by inverting the dir pin for y2 or is there a better way of doing it?
14 Mar 2021 17:51 #202232
Replied by PCW on topic Gantry System reversing direction of Motor on y2
I think there are at least four ways to do this, 2 in hal and 2 with wiring changes:
1. Inverting the direction pin in hal
2. Changing the sign of the step scale in hal
3. If you are using differential drive so you have
DIR+ and DIR-, swapping these will reverse the direction
4. Swapping polarity on one of the motor windings
Your choice...
Your choice...
- Creative25
14 Mar 2021 18:13 #202238
by Creative25
Replied by Creative25 on topic Gantry System reversing direction of Motor on y2
Thanks for the info I did not know of swapping the dir pins , do they actually swap polarity?
I will use one of the wiring methods to keep it simple.
15 Mar 2021 15:19 #202358
I would always do it in HAL, to keep it simple.
You will always have access to HAL, but wiring gets buried in the machine.
I generally change the sign of the step_scale.
Replied by andypugh on topic Gantry System reversing direction of Motor on y2
- Creative25
15 Mar 2021 17:35 #202375
by Creative25
Can’t find step_scale in Hal only in the ini file.
15 Mar 2021 17:54 #202377
The HAL reads it from the INI, so change it in the INI.
The following user(s) said Thank You: Creative25
- Creative25
15 Mar 2021 17:59 #202378
by Creative25
So basically I change the number that is there into a minus number
For example from 67 to -67 ?
15 Mar 2021 18:04 #202380
Exactly.
- Creative25
15 Mar 2021 18:48 #202386
by Creative25
It works.
Time to create page: 0.121 seconds
