Spindle - 7i76e
02 Apr 2021 10:01 - 02 Apr 2021 10:41 #204473
by Fiury
Spindle - 7i76e was created by Fiury
Hello,
I am useing:
linux mint, linuxcnc, mesa7i76e , VFD Huanyang
I have problem:
with Spindle - pin2 on TB4 is stil 0.14V and not increase..(like potentiometer)
+10 to Pin 3
VI to pin 2
ACM to Pin 1
FOR to Pin 6
REV to Pin 8
DCM to Pins 7 and 5
Then Configure the VFD
PD001 = 1
PD002 = 1
PD044 = 1
PD045 = 5
Thank you
I am useing:
I have problem:
+10 to Pin 3
VI to pin 2
ACM to Pin 1
FOR to Pin 6
REV to Pin 8
DCM to Pins 7 and 5
PD001 = 1
PD002 = 1
PD044 = 1
PD045 = 5
Thank you
Last edit: 02 Apr 2021 10:41 by Fiury.
02 Apr 2021 12:12 #204489
Replied by PCW on topic Spindle - 7i76e
When you test, what are the values of these hal pins?
hm2_7i76e.0.7i76.0.0.spinout
hm2_7i76e.0.7i76.0.0.spinena
Also did you measure 10V at 7I76E TB4 pin 3 relative to TB4 pin 1?
02 Apr 2021 13:33 - 02 Apr 2021 13:42 #204498
by Fiury
Replied by Fiury on topic Spindle - 7i76e
Yes 10V was there, hmm ok it is working now, probably i had linuxcnc switched still ON and restart only mesa and VDF.
Now mesa working well. (good Volt in pin 2... 1,6 4000rpm 0,8 2000rpm.... sorry to bother you)
But still have problem with VDF , it is reacting only to FOR and STOP
Not reaction on ,speed , REF. Interesant :-D
Anything else to set on VDF :
PD001 = 1 (external terminal)
PD002 = 1 (external potentiometer)
PD044 = 1 (for RUN)
PD045 = 5 (FOR /REW)
Is this correct ?
PD044 = 1 (for RUN)
Is this correct ?
Last edit: 02 Apr 2021 13:42 by Fiury.
02 Apr 2021 13:45 #204500
Yes you would normally need to configure the VFD for RUN/DIR mode
rather than FWD/REV mode
02 Apr 2021 14:12 #204505
by Fiury
(btw , thanks for helping PCW !!!!)
Perfect after many tries also RUN/DIN is running
Last thing to fix control by Mesa potentiometer ... stil can be up/down only manually on VDF.
Mesa giving Volts, but cannt be controled by linuxcnc. Trying and studing VDF, must be there.. somewhere..
02 Apr 2021 14:45 - 02 Apr 2021 14:51 #204508
by Fiury
Shit , two news:
1) great , all function on:
PD002 = 3 (which was not in manual)
PD044 = 1 (for RUN)
PD045 = 5 (DIR.......FOR /REW)
2) Spindle burned
- otherwice watter flow thru spindle , spindle burned and is KO
Is any difference , which is IN and OUT for watter ? Or orientation of spindle (i had it on floor- flat)
It flows tru then thought that it is ok
PD044 = 1 (for RUN)
2) Spindle burned
Last edit: 02 Apr 2021 14:51 by Fiury.
02 Apr 2021 23:34 #204577
It should have been OK, yes.
Perhaps you were running it at too low a speed?
Replied by andypugh on topic Spindle - 7i76e
03 Apr 2021 07:58 - 03 Apr 2021 08:05 #204598
by Fiury
I runned about 300-500rpm about 1 min without watter, then i start cooling (1min) then i started spindle and in 15 sec for about 8000 rpm was KO.
If you have idea why it was burned ? To avoid to burn next spindle..
a) spindle cann´t be horizontaly , must be verticaly ?
b) is difference IN /OUT wotter on spindle ? I don´t think so watter flowing thru..
c) some next setting on VDF ?
I had thisone www.aliexpress.com/item/32695905414.html...3.0.0.4e136326rt8vVc , i will probaby order next, but not so rich to burn one by one :) , need some help why..
With VFD Huanyang 2,2 kW..
Last edit: 03 Apr 2021 08:05 by Fiury.
- Mike_Eitel
- Thank you received: 185
03 Apr 2021 14:20 #204624
by Mike_Eitel
Replied by Mike_Eitel on topic Spindle - 7i76e
In any case:
Ask the seller.
Describe that it was without load.
Minimum speed 300-500.
Ask if position must be vertical
Ask what max temperature water has to come Out. (not in)
Ask the seller.
03 Apr 2021 15:09 #204627
by Clive S
Replied by Clive S on topic Spindle - 7i76e
Has this ever run with the parameters before.
Have you check the number of poles some of these vfd's come with them set at 2 or 4 if I am not mistaken I think they should be set for 2 PD143
Time to create page: 0.330 seconds
