Error on "Test / Tune Axis
- charleyann
- Thank you received: 10
05 Apr 2021 22:13 - 05 Apr 2021 22:27 #204971
by charleyann
Error on "Test / Tune Axis was created by charleyann
In the Pnc Config Wizard I am getting this error when I select "Test / Tune Axis"
If I comment out the print statements at line 689 the test runs. I don't know enough about python to fix it the right way.
Can anyone help?
Can anyone help?
Last edit: 05 Apr 2021 22:27 by charleyann.
05 Apr 2021 22:19 #204972
Replied by cmorley on topic Error on "Test / Tune Axis
your quotes didn't come through.
What version of linuxcnc are you using?
- charleyann
05 Apr 2021 22:26 #204973
by charleyann
Replied by charleyann on topic Error on "Test / Tune Axis
I'm running 2.8.1
I fixed the attachment, you should see it now.
05 Apr 2021 22:50 #204979
change it to this:
if that works I'll push the fix
for i in stepinvertlist[0]:
halrun.write("setp " + self.step_signalname + ".step.invert_output true")
for i in stepinvertlist[1]:
halrun.write("setp " + self.step_signalname + ".direction.invert_output true")
halrun.write("setp %s.step_type 0 \n"% (self.step_signalname))
- charleyann
06 Apr 2021 13:07 #205100
by charleyann
That took care of it.
Thank You
I'm off to my stepper tuning adventure!
Thank You
Time to create page: 0.234 seconds
